Originally posted by friskyfrankie
View Post
Cooling problems
Originally posted by 91merc View PostI pressure washed the radiator yesterday, and the cooling system is pretty rusty, I flushed it probably 25 times and still brown
I did the water pump several months ago, and it was darn near spotless inside:
Despite common myths, a cooling system still needs a working fan at speed. (aka: its b.s. that you will run cool on the highway without a fan) If your fan clutch isn't working properly it can cause an overheat just for the fact it is not moving enough air. Get the car hot, open the hood, turn off the engine while keeping an eye on the fan. If it keeps spinning after the engine shuts off, replace it. It'll move a little bit (as in less than one revolution) but it should stop with the engine, especially if its up to temp and has gotten good and warm.
Yes if the fan spins for as long as a full second after the engine shuts off it needs to be replaced.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
if its that nasty I might be tempted to yank the block drains first and get as much loose crap as possible out of the block before using any sort of cleaner. No point in making it work extra hard if you can dump a fair bit of the crap first.
Looks like ThermoCure is an Evaporust product? I've used Evaporust on stuff before, does work well, but it does indeed turn rust black. I don't recall it smelling like much of anything so it must have some extra herbs and spices in it.
thing with pressure washing a radiator is that it won't dissolve any crap thats stuck in the tubes and causing it to not flow or transfer heat effectively. I have cleaned heat exchangers with muriatic acid before, common thing on boats, but those are bronze. Not sure what that would do to aluminum. Vinegar might be an option though. Cleaning vinegar is a little more concentrated than food grade. If you pull the radiator and lay it flat, then fill it with vinegar it should dissolve out any lime or rust if you let it sit for a few hours.86 Lincoln Town Car (Galactica).
Well I'm going to install some guages and go from there, yesterday it took about 60 miles for the engine light to come on. The radiator hoses were solid and no coolant was boiling out, but it got the th point where it had a shudder to it so I had to let it coolLast edited by 91merc; 08-21-2022, 09:54 AM.
Originally posted by 91merc View PostI think I might also put a NEW fan clutch, cooler thermostat, and do a ThermoCure flush
Thermostat sets the minimum engine temperature. Max is determined by how effective it is at dumping heat, so basically radiator condition and air flow through it. Good to know that the thermostat is actually opening when it should though. Can check that on the stove with a pot of water and a thermometer. if it doesn't open within 5 degrees or so of what its marked, its junk.86 Lincoln Town Car (Galactica).
and this is why running straight water even in places that dont freeze is a terrible idea. Can run leaner than 50/50 and get a bit extra cooling capacity but the antifreeze is also a corrosion inhibitor and water pump seal lube. pure water is technically a better heat transfer fluid but that goes right in the toilet when the block rusts and plugs the cooling system up.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postand this is why running straight water even in places that dont freeze is a terrible idea. Can run leaner than 50/50 and get a bit extra cooling capacity but the antifreeze is also a corrosion inhibitor and water pump seal lube. pure water is technically a better heat transfer fluid but that goes right in the toilet when the block rusts and plugs the cooling system up.
Gotta love previous owners
