I got a solid 47 PSI of oil pressure hot. Is the REALLY REALLY good???
How good is 47PSI??
I got 0-8psi for about three days. Then I parked it. I've been swapping motors since, thanks to assholes like you guys saying, "Oh- install this!" and I listen. Dicks.
I'll let you know soon. I have to check mine and make sure I don't have a problem.
I hope I just had a worn lifter and not an oil pressure problem.1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
Supermotors
I idle at about 25-30 psi hot and thats a low mileage motor. Mine is really loose tho. All the clearances are within spec, but barely. 47 psi hot idle is pretty frickin awesome.86 Lincoln Town Car (Galactica).
