so i want to punch out the stuf in my cats (89 CV) do i have to take them off the car? or can i get the stuf out when i take of the y-pipe? thanks
CAT'S...
I've got that done with my '88 Ford.
If your state requires emissions testing with a breathalyser- type device, then don't do it. It will never pass. If it's just a visual inspection, then go ahead. Don't worry as long as the mechanic doesn't have x-ray vision, you got nothing to worry about.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Originally posted by Ivan DAssuming 4-cat system the main (bottom) cats you can probably do while on the car, to get the top ones though you have to take the downpipes off.
Taking downpipes off ain't such a big deal, you got two nuts on each side - use some thread release chemical stuff, spray it on the studs several times before you go do the job, then run the engine till the manifolds warm up, get your ratchet, the 10" extension I mentioned you, a deep socket (11/16" IIRC), and a breaker bar (just in case), and get them bitches off - should take you less than half an hour including jacking up the car and putting her on stands.
Originally posted by beep_beepyeah well emissions is not a problem here
No emissions testing, no visual or equipment testing, no inspections for anything.
You just send in proof of insurance along with your payment each year and they send out your annual 'sticker' for the tag. (Only one tag, none for the front)...
Anything goes here when it comes to vehicle modifications."Ad eundum quo nemo ante iit"
Which is why I aint changing...1983 Grand Marquis 2Dr Sedan "Mercules"
