OH MY G-HOD, I have about had it with trying to find the source of this thing. I'm going to check the timing 1 more time, and if thats not it than I don't know what I'm going to do.
rough Idle problem lives on, wasn't the injector
When are Scott and Thain comming through Raleigh??? I really need their help, b/c no shop will work on my lincoln because its no origional.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
PM me your phone number, mang....Originally posted by 89LincolnTWNcarWhen are Scott and Thain comming through Raleigh??? I really need their help, b/c no shop will work on my lincoln because its no origional.1983 Grand Marquis 2Dr Sedan "Mercules"
Nobody understands non-stock Lincoln. Its a Mark VII with a backwards intake and people act like its something magical and mysterious. I'd love to drop my car off somewhere and ask for the brakes to be checked. I'd get an estimate with some huge bill for replacing half the front suspension with "correct" parts.86 Lincoln Town Car (Galactica).
