well i brought my car for emissions this week but it failed to much carbon so my mechanic basicly fiddled around with the pvc valve and idle, took out the the vavle and basdicly made it idl to where it didnt even run but know i realy thining about carb swap so i need to know a exact detail list so i know what to get when going to carsile and well do i need to hook up vaccum lines
ok well i failed emissions but my mechanic fiddled around wit the car and got it pass
4bbl intake, any duraspark distributor for a 302 (with the cast iron gear, mine if off a van but most say the one for a mustang) and all the duraspark shit..
Oh yeah, a 4bb carb, the lokar throttle cable, TV cable, and bracket...
I can probably think of more, but im tired lol1983 Grand Marquis 2Dr Sedan "Mercules"
Is that a NJ license plate? Let's make some horse power. Do a complete tune up and put it on a dyno to get the baseline numbers. After that add a Weiand Stealth intake and a 600 cfm carb.
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
On a tired motor with miles I'd just put a 2bbl on it and call it a day. No intake manifold swap needed, just unbolt the CFI and slap on a 2150. Can probably even come up with a way to keep the TV rod on the 2150 if you get creative with it. The only other thing you'll need to deal with at that point is getting the fuel pressure right. Either remove the in-tank pump and make a pickup so you can run an electric or mechanical pump, or get one of those fancy dancy fuel pressure regulator things that uses the stock pump and return lines and lets you adjust the pressure the carb gets.86 Lincoln Town Car (Galactica).
Really don't have to do anything creative with the 2 bbl, if you get an 81 t-bird carb, they came equipped with engines with AODs, so it would hook up directly. Like what gadget said, not really worth buying a bunch of expensive parts to put on a worn engine like that. The gains probably wouldn't be worth it
http://www.dynojet.com/maps/autodynos/nj.htmOriginally posted by 83countrysquireyeah where can i find a dyno and doesnt cost like 500 dollars
Pick a shop and tell them you just want to get your baseline numbers. It should only cost you $50-$75.
well my engine has 150000miles and its running strong my mechanic says it should lastme to 200 or more but i want power and i want to use the 302 i have for know so what do i need wieland stealth intake whats thebest 4bbl carb for my area i dotn know how tro tune that much what specfic disburtor and ingintion stuffsigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
what can i do that will make my car run better on a daily basis so that i can get decent gas mileage and still got a little power behind her and not fail emissions how do i stop the richness should i put back my egr sensor that went into the manifoild???????sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
I take public transportation during the week and only drive on the weekends. I get great gas mileage!!!
I don't worry about my car's MPG. When I get down to a quarter of a tank, I just fill it up again.
What's your gas mileage now?
The EGR valve is on the intake manifold. If you removed it, put it back. Believe it or not, you'll use more fuel with that unplugged than connected because the computer expects it to be there. Running with EGR actually will keep the engine from pinging too. I'd also suggest removing it and cleaning the EGR valve and spacer plate under the CFI unit along with a tune up if the plugs and wires and such are old.86 Lincoln Town Car (Galactica).
