Yeahhhh buddy. Working A/C is a great thing.
I bought the shorter 5060560 belt to make my air conditioning function without an air pump installed.
Installing it is not as easy as loosening the tensioner and slipping the belt over. You need to remove the two bolts holding the tensioner and remove it. Install the belt, then reinstall the tensioner to its normal place.
I found it easy to install the bolt to the rear of the tensioner by crawling underneath. I must have lost my original bolt for the rear portion, but it I bought a 1.25" 3/8" bolt to install.
I replaced the alternator/water pump/steering belt as well, since we used the old one on the original engine swap. It would squeal above ~4000 RPM.
After everything was re-tensioned I fired it up and made sure it looked good. I had never tested the compressor clutch before today, so when I put it in the A/C mode and the clutch didn't kick in, I was a little dissapointed.
No worries though, Epi taught me a nice trick a few years ago. I used some jumper cables and two small pieces of wire to test if the clutch worked. Sure enough when I gave it 12 volts it kicked on! I wired up someting quick to run the clutch (and the compressor under load) so I could refill the system, because we released some when we did the engine swap.
Using the jumper cables I slowly filled the system back with three cans of refridgerant (R134a) and oil (2oz.). The compressor was freaking loud when running, even after three cans, so I think it needs a separate can of oil alone.
Everything electrical on the car works fine, so I figured there had to be something simple to why the compressor clutch was not kicking on when put in AC mode. I decided to look at the fuses and did not see anything explict to the AC system. I had one fuse missing for 'Fog Lights and Accesories" so I said what the heck and stuck a fuse in there. Sure enough I turned the HVAC control to AC and the compressor clutch kicked on!
Took the wife out for dinner tonight in the car, much to her surprise of hearing the car has functional air conditioning now. I told her I spoil her.
On a funny note, she said tonight my car is no longer an old man's car! Because the old man would have died by now, lol.
~Adam
~Adam
