Sorry to be silent for so long, I just developed a tendancy to be a lurker.
Well, I'm pretty sure my transmission is starting to go bad...The shift from 1-2 has become very rough, and the shift from 2-3 takes longer than usual. Overdrive seems to work, but if you are cruising along, and give it gas, it will no longer kick down a gear or two. It will just stay in third or OD.
First chance I get, I'll get the fluid changed in hopes that it will help, but otherwise, it might be a more costly repair...any ideas?
