Ran my KOEO test Need Help
    It looks like you're holding some split loom tubing to me? If so, thats just plastic junk covering wiring, unless I'm not looking at what you mean.
      Humm, let me see if i can get a better pic :->
      Ok what my thumb is on with the Duct tape on the end, thats the end part where it comes from is. right there on the EGR valvue hopefully this helps :->, o and i got that other line back where it was suposed to be the one. that was comeing off the pcv valve ;-)
      Thanks Dark
        god what a pain in the (_o_) sensor to change.... the tp sensor that is. im stuck on trying to fig out how to get that middle pice out of it...
          :confused: Is it broken in pieces? After you take the 2 screws out it just lifts up.
            Jason, his is a CFI car...
            The TPS on them is MUCH more of a pain in the ass.
              I got the part on there, butt.... that thing ( I dont know what its called. ) That has three pices I, Dont know how to put it back on right. and i dont even know what it's called. As well as it had some sort of washer That kept it from comeing off, i used some needel noise plyers on it to try and ply it off and it bent off. Any one know if this is a esental pice? And better yet what that thing is called and where i might get a diagram of it so i can tell how to put it back on?
              Sorry if it's hard to make since of this. It's screwing with myhead though,...
              Thanks agine
              Dark
              :::: God i fill dumb ::::
                ll post an Update./ We got that thing back on, We fist put the spring in the im guessing the idle lever then put the idle lever over that bolt/screw thing that comes out of the carb. then we put thescrew ajuster on the end of it and got it all lined up. then caped it off with the nutt. I then ounce agine cleared the computer and cranked her up and Varom, off she went. Only thing is she keeps " Poping " and she flooded twice.
                Im thinking though that my timing is off, for the reasson of the poping, and the screw ajuster needs to be retarded for the flooding. what do you guys think?
                If you guys have any coments or sujestions let me know :-> And i hope if any of you run into this prob yourself it will help :->
                Thanks Agine,
                Dark
                  Oh :drug:
                    :::: Shakes head ::: Good luck brother hopefully u wont have to ever put that dern thing on. Ima take a pic of the little bugger that makes it a pain in the arse so you know what to look for :->
                      BUMP>! Could any of these old "Fixes" Have actualy made my car act worse? I member the EGR sensor and TPS both of which came from autocrap parts stores.. And this is the earliest I talked about Poping! hehe
