1. door lock solenoid
2. window regulator
3. window motor
"Thermactor Reducer"..... I have never seen it referred to as that, although it should be a technically correct description..... Ford uses these basic thread insert/blind hole inserts to "plug" up the holes in the ends of the heads which do not have the "smog tubes" attached to them and to reduce the thread size so that you can attach accessory bolts to the heads... If you are using them to plug holes in the "back" of the heads after removing the tubes, it is necessary to chase the threads first as they will be plugged with carbon....
and the heads just look like the valve seats have been hardened
That is your basic GT40P chamber for the benefit of those who have never seen how the spark plug is extended into the center of the chamber.. I have 1 set of these brand new bare heads left.......
dont mind me just stealing bandwidth to show parts that go with the turd
I haven't fucked with it as it makes my geiger counter go ape shit when I'm near it. Also I get a wierd vibration above 88mph. I think its my u-joints.
are you sure your supplying the proper 1.21 Gigawatts?
My Pic 2 is a pressure plate to flywheel bolt for those doing a 5 speed conversion. Pic 3 is a converter to flexplate nut for those who have rounded off nuts......
