Hey I'm looking into the future right now, about my transmission. I want something that would get this Towncar really moving like a 4R70W and some 4.10 gears. What's a wide ratio transmission's advantage over a regular AOD gearset?
good automatic trans upgrade?? 4R70W?
are you talking about a complete 4r70w swap or an aod with wide ratio planetaries? you can run a 4r70w but you need a bauminator and their valve body to control the shifts
other option which is much cheaper is an aod with 4r70w planetaries...........brian will do em up here for around 1200 installed
yea if you get one from a 3.8 v6 car
And the last 2 or 3 years of 5.0 Explorers had them. You could just use a Lentech full manual valve body in it. No need for a computer.Originally posted by BoxManWill a 4R70W even bolt up to a 302?http://secondhandracing.com/Home.aspx
The AOD with the planetary gears sounds nice. I'll come visit Penn once my AOD decides to take a crap.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
The 4.2 litre pickup trucks also have a 4R70W which bolts to a 5.0 motor.86 Lincoln Town Car (Galactica).
