Underdrive Pulleys Junkyard Style
    From My Own Research I Have Found Out That The Crown Vic,Marquis And Towncars Stock Water Pump Pulleys Are The Same Diameter As Any Offered Underdrive Pulley Kit For A Mustang 86-93. So From The Factory We Are Set This Was Just Unknown To Many. The Only Difference Is Our Belt Is 6 Rib/Grooved. To Achieve The Alternator Having The Right Underdrive Pulley Simply Do The 3G Alternator Conversion. If You Have Already Done This And Retained The Same Pulley As The 3G Originally Came With Then You Are A Step Ahead And You Have Just Come To Know It. The Reason Being Is The 3G Alternator Pulley Is Real Close In Diameter To The Alternator Pulleys Offered With Any UDP Kits On The Market. Here Comes The Fun Part The Crank Pulley, Somehow Some Way Just Get The Proper Crank Pulley From Ebay,Craigslist etc. (Message Me And Ill Sell You The Proper Spacer & Bolts) For $50 Shipped Paypal Note:You Will Need A Shorter Belt Autozone P/N 480K6
    sigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
    The offset is not the same. We use a two belt arrangement vs the Fox single belt. The Fox belt is almost exactly in the middle of our two belts, so sticking a Mustang water pump pulley on will not make things line up at all. Using Mustang crank pullies won't work because not only is the belt in the wrong spot, there aren't enough of them to drive all the accessories. I suppose if you put a spacer on and removed the AC it works, but who in their right mind removes an air conditoner?
      No one.
        racers, weekend dragsters, those in climates that the temps never get above 70F (Alaska, some of Canada, etc). A/C used to actually be an option.
          I remove air conditioners. They are useless.
            defrost works better with an operational AC system to pull the humidity out of the air. I also dislike to sweat, and I drive a Lincoln with heavily padded velour seats. AC is not optional in such a vehicle when you don't want your seats to reek of swampass.
              :lol:
              true dat. Swamp ass is bad mmmkay.
                No a/c in mine here in sunny florida. Thats why god made windows.
                  A/c is more stuff to break. But if it works fine I won't disturb it. (Except my 91, winter beaters don't need a/c even if it ever so slightly helps pull moisture out of the air)
                    __________________
                    technically only left handed ppl are in thier right mind, but no ac in me linc cause im hardcore lolz
                      http://carphotos.cardomain.com/ride_...0056_large.jpg
                        A person who wants to go fast,and im left-handed
                          Interesting. What is it you're actually using for a crank pulley, though? Am I to understand that it's basically a water pump pulley mounted with a custom-built spacer?
                            Let's keep the bullshit out of the tech forums, or people are going to get hurt.
                              I make the spacer and the longer bolts come with it for 70 shipped. Just remember some of you said it wasnt possible. Just get a bottom crank pulley from a fox body and Paypal me $70 and you have underdrive pulleys, but no a/c or smog.
