Big Brake Swap
Looks great, if you plan to whip up some more let me know.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Hi,
Is the Eastwood unit China made?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by JeffBoudah View PostThese are what the production plates will look like. Bend lines will be etched. $20+ shipping sound good?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Anything on how they perform? I take it you're just selling just the metal to box them in, right.
Looks pretty.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
ooh? i'll take a set if they are affordable.
Originally posted by pantera77 View PostSounds good to me, I'll buy a couple sets.Originally posted by Bobcat View PostAnything on how they perform? I take it you're just selling just the metal to box them in, right.
Looks pretty.Originally posted by Lincolnmania View Postooh? i'll take a set if they are affordable.
These will be 1 step thinner @ 12 ga. cold rolled steel. 11ga was a bit thicker than the base arm material.
Tips... clean the weld surface really really good, tack it all in first. Balance your heat side to side, and end to end so you don't warp the arms, clamp a bushing in the open upper arm's end to keep the spacing right. If you 'over bend' the end tabs on the long bars don't worry, just clamp them down and weld them in.
Any guarantees that these won't rip the mounts out of my nice, mostly rust free frame?1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
If you stick with rubber bushings or ES Poly, there shouldn't be any issues. Fully boxed might have issues... but this design allows some flex still. If there's any concern... double plating the frame mounts (welding another plate to the outer side of the mounts and to the frame) or adding angle braces to the mounts will sort that.
