Alright… my ball joint popped out on me today, i guess I do own a shitbox. It fell out in a parking lot on my way home. I kept hearing a rattling and thought it was my exhaust Thats held on by a clothes hanger shaking around, which it does. Obviously im about to replace both ball joints and it looks like my backing plate for my rotor is bent, don’t know if the rotor itself is. Anything else I should replace that might’ve been affected? It landed on the control arm so I guess I’d replace both of those too.
Ball joint broke
Just replace the ball joint. The splash shield looks to be plastic. You could just zip-tie that crack or if you have access to one of those plastic repair hot wire tools, you could use that. I used box staples to fix my bumper, so those would probably work as well (use like the zip-tie trick). Unless the rotor was damaged by the control arm, you probably don't need to touch the brakes.
As for which brand... Anything in the "daily driver" section on Rock Auto is a decent brand. You're not going to get much different between them all. They are a better quality tier compared to the economy parts.
Edit: Broke out the posts into their own thread because it's a different topic.Last edited by sly; 05-20-2025, 10:54 PM.
Your sway bar endlinks don't look so awesome, throw a set of those in the cart while you're at it. Just be careful when you do this, there is a heck of a lot of pressure on that spring.
If one blew apart, expect the other to be just about as bad.86 Lincoln Town Car (Galactica).
Yeah I was gonna get those too while I was at it. I was about to go with moog but I didn’t know they went to shit so I got Delphi ball joints. The ball joint will be in before the endlinks so I’ll probably be driving for a few days on the old ones.
Edit: how is mevotech as of now? I’ve heard good and bad things from them recently.
Mevotech seems to be about on par with Moog currently. You might get good stuff... you might have to warranty it.
Mevotech is apparently Canadian. I always thought they were China because everything is.86 Lincoln Town Car (Galactica).
The company may be Canadian but I believe the parts are actually made ibn China. How good is the quality of their parts? No personal experience so it is a crap shoot like most other aftermarket parts (and now even most if not all OEM).Originally posted by gadget73 View PostMevotech is apparently Canadian. I always thought they were China because everything is.What I Own: 1993 Mercury Grand Marquis GS
Given how garbage everything has become I don't know that they are likely to be worse than any other garbage, just possibly costing less for the insult. I might own a set of Fox inner tie rod ends that they made but I think they are in the box of clearance items, not actually installed on anything.86 Lincoln Town Car (Galactica).
Couldn't agree more! Chinesium parts are, as previously stated, a real crap shoot!!Originally posted by gadget73 View PostGiven how garbage everything has become I don't know that they are likely to be worse than any other garbage, just possibly costing less for the insult. I might own a set of Fox inner tie rod ends that they made but I think they are in the box of clearance items, not actually installed on anything.What I Own: 1993 Mercury Grand Marquis GS
sure, give it a go. Its got to come out somehow.86 Lincoln Town Car (Galactica).
Might use a bushing/ball joint remover to press the bold out (put the catch cup on the threaded side of the C-clamp and use the static end of the clamp to press on the bolt). Get a lot of tension on it and if it doesn't come loose, whack the knuckle with a large hammer to get some vibration into the thing and it should pop out. Make sure to hit only the knuckle and not the press.
- Likes 1
Alright… I tried a lot of methods and multiple ball joint separators. The method im on now is using this tool and I was sure it was gonna work, but the moment you put any kinda hard tension on it it slips cause the tip of stud isn’t flat. The options im thinking of as of now are buying an angle grinder and grind it down so it’s flat, calling someone else to try and do it, or going to the junkyard and taking the upper control arm from the 89 I saw (last resort). Any other recommendations?
