2000 Grand Marquis LS
Mercury Owners Group member
Latest tires I am using on my boxes 265 50 15 front and 295 50 15 rear Hankook. Very close to the BFG 275 50 15s used to use on the front that were discounted. Wheels purchased for the wagon 8 x 15 4" offset Crager. Rear are 10 x 15 5" offset vintage wheels. Going to install OEM hub caps before long
Just found this site the other day: https://www.wheel-size.com/
I'm starting to poke around that site a bit, and it looks like there is some good info on there.
I might pick up some AR outlaw ll wheels. 15x8 if the will work.
No idea what backspacing.
Would a 235 75 15 fit in the front without contacting the uca?
Or would s 215 70 15?
Anybody know what the max size on american racing 15x8 would fit in the front?
The inside will be fine. The AR’s in 15x8 list a 3.75 backspace. I’ve run a 4.125”, it was close but never rubbed.
The stock steel wheel is a 15x6 with 0.45 offset, which means you’ll have roughly 2.5” of rim outside of the hub mount. The AR’s in 15x8 with -0.75 offset which puts you at 4.75” outside the hub mounting surface. You can figure that might be a problem... I really don’t know for sure, and it does depend on tire size. Take a look at your stock set up and turn the wheels to check your tire to fender clearance in several different positions and check for at least two inches of extra clearance. I would hazard guess you’d need a short tire to make that work. The 15x7 version cuts an inch off the outside which would help.
A 235/70r15 fits a stock rim in the front without issues. Not sure about taller.
