Buying control arm bushings (need to make sure I have everything I need
They have them for the newer vics, trying looking under a 1995 crown vic, they are there. They even have motorcraft, but at around $190-Phil
Wait, am I hearing this right, I can get control arms from a 95 vic to go on a town car.
I think i read about this here, that a 90's Pnather control arm can work on a box. Can i please get some validation on this"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
As far as I know all lower control arms are the same 80-02 on CV, GM and TC
I've always gotten mine at either Advance, Auto Zone or O'Reilly.
They come with bushings installed and that makes things a lot easier.
Auto Zone part number is 520-207 drivers side and 520-208 pass side. $165.99 each.
And with some shopping around you may find them cheaper than that.
IF, you are going the big brake route, Amazon is your friend.
http://www.amazon.com/Raybestos-507-...ar+control+arm
What if I am not going down the big brake route...is this still my friend???
Also, in addition, I found some control arms raybestos (prof grade) complete control arms that comes with the ball joints and bushings.
Alost seems to good to be true!!!
5071153, 5071154. I betcha the ball joints aren't greasable!!!
Originally posted by piranah View PostIF, you are going the big brake route, Amazon is your friend.
http://www.amazon.com/Raybestos-507-...ar+control+arm"To Find yourself, you must first lose yourself"
Lowers are interchangeable 79-02, however the ball joints changed in mid 94 IIRC, so unless your swapping knuckles/doing the big brake swap just buy the earlier ones.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
I don't if they do. All I have to go by is the picture"To Find yourself, you must first lose yourself"
that's a hell of a deal. Definitely the way to go next time I dick with any of that noise.
I need to confirm that these ball joints are greasable (confirm they have zerks)"To Find yourself, you must first lose yourself"
Dorman site shows non-greaseable on that part. Jerks.
Originally posted by porschpow View PostBTW, rockauto doesn't have the whole control arms. Where are you reading or seeing control arms for $70??
YEAH THE WAY ROCKAUTO IS is that they won't have 89 lincoln town car conrtol arms but for the comparable CV or MGM... ...that same year, you do. Go figure. Those people that don't know how Panthers are would be highly discouraged. The AC delco prof series complete control arms are a good deal (and include the greasable ball joints and bushings!!!)))
Anyways, I need to get the front end fixed, this is higher in my priorities than the 3G alternator upgrade and the headlight relay upgrade."To Find yourself, you must first lose yourself"
