Originally posted by 70torino429
View Post
would a c6 or e40d fit?
Originally posted by Grandpaslincoln View PostThe diesel e40d computer isn't going to help you much, they are designed to make the transmission shift within a diesels power band, if you put it on a transmission behind a gas engine it'll shift way too soon.
Any stock ECM used to control an E4OD or any other electronic trans for that matter is going to have bsaically the same inputs, diesel or gas. The specifics may be a little different, but it still needs all the same data points to work right. The other logistical concern is where the heck do you stick a second ECM with all it's wiring?Last edited by gadget73; 06-13-2009, 04:02 PM.86 Lincoln Town Car (Galactica).
The lever was stock with what came out of the van. E 250 with a 300. Bolted right in the truck after I built a new driveshaft. Dont remember anything about the crossmember though.1989 Grand Marquis LS
Originally posted by gadget73 View PostAny stock ECM used to control an E4OD or any other electronic trans for that matter is going to have bsaically the same inputs, diesel or gas. The specifics may be a little different, but it still needs all the same data points to work right. The other logistical concern is where the heck do you stick a second ECM with all it's wiring?
Originally posted by 70torino429 View Postid really appreciate it if you could get some measurements, but im in no hurry really, so take your time.
most of the ones ive seen, as far as small block c6s i see are mostly in late 80s-early 90s broncos and ford pickups, and theres plenty of those in junkyards. im not sure what year exactly they did away with them, somewhere in the early 90s (somewhere around 91-93 i think) they all got replaced with the e40d. but the majority of the late 80s ones could still be had with a c6, ive only seen them on rigs with the 351, so i dont know if they came on 302 trucks, but i would assume its a possibility.
I have seen a C6 used from factory in a mid production '96 F-250 with a 300 in it.1990 LTD Crown Vic w/ dead 5.0
1984 Pontiac 6000 cammed 2.5L Iron Duke
1986 F-150 300 6cyl 5spd.
1994 Crown Vic... Free, bad trans?
Ok, so upon further research, a 3 speed auto such as the c6 might be what i want.
If this calculator im using is at all correct, the following info is what ive gathered.
All calculations were with 27" tall tires, and a 3.55 rear gear ratio.
In second gear, at 2000 rpm, you would be going 62mph
second gear, at 2500rpm you would be moving along at 77mph.
third gear, 1800rpm you would be going 81.5 mph
third gear, at 2100rpm you would be going 95mph.
Am i the only one that finds these calculations a little too good to be true? It seems like attaining respectable highway mpgs, would not be hard at all with the c6 if these calculations are correct.
Originally posted by 70torino429 View PostOk, so upon further research, a 3 speed auto such as the c6 might be what i want.
that doesnt sound rightBuilder/Owner of Badass Panther Wagons
most transmissions use a 1.00 3rd gear.
2500 rpm, 3.55 and 27" tire from that calc is 56.6mph which sounds much more realistic. Driving a c4/c6 is like driving an AOD in 3rd all the time....Builder/Owner of Badass Panther Wagons
