A/c still kinda wierd when on gas...
    i replaced the soup can and it still kinda goes to defrost and blow heat under a load i know i should check for more vacuum leaks where should i start thou... its not as bad as before but still happens
    thermal blower lockout and the check valve at the firewall would be my guesses.
      where can i get a new one if its it and how do i tell its bad??
        whats the check valve look like??
          ok i took out and deleted thermal blower lockout... still happens and the check vavle is the thing right under it right with the copper tubbing... I took that off by acciedent when i deleted my smog equipment
            no, not that check valve. When you deleted the TBL, did you seal up the lines properly? If they're not sealed, thats the problem.
            Info on the check valve, including how to test it:
            http://www.lincolnsonline.com/tech/00130.html
              whats the proper way to seal them
                I was just reading the that lincoln artical and it says cans with more than one port has check vavle built in the new one i have does could i possible make use of this if its correct
                  You just have to make sure they're sealed up completely. I've used snug fitting screws dipped in RTV to seal those up.
                  No idea if they have a check valve or not. Not sure how one would work, unless its got a dedicated vacuum source and vacuum load ports. I would just use the stock check valve, and plumb the hose to a port that has no check valve. Be sure the un-used ports are all capped off too.
