I just did a 3g upgrade on the '90 today. Found a junkyard small case 130 amp unit from a '98 Mustang. I used a 56mm pulley from Ford. You can use a 65mm, but getting the belt on is a bit of a fight.
This unit originally came with a 70mm pulley and I was worried I wouldn't be able to use the stock belt. The one from Ford was about 20 bucks I think.
I re-pinned the voltage regulator connector and installed a stator jumper from the junkyard. That allows you to use your existing harness with it's fusible links.
Need any more details, don't be afraid to ask. Myself and I'm sure others here would be happy to help you along.
