does anyone have a ECM pinout diagram for a 1990 GM? getting a standalone made to be plug and play but they're asking for a pinout.
ECM pinout
I do not, but I wonder if this page might have what you need:
http://www.grandmarq.net/oldfuelinje...0Lpinouts.html
Here's one from the 90 EVTM
Sent from my iPhone using Tapatalk1990 Country Squire - weekend cruiser, next project
Are ‘89 and ‘90 pinned out the same? I bought an ‘89 EVTM and there is NO ECM pin out.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
They use the same computer, so it should be pretty similar, if not identical.1990 Country Squire - weekend cruiser, next project
ECM pinouts: http://www.grandmarq.net/oldfuelinje...0Lpinouts.html
Yes, they should be the same unless the 90 uses California MAF setup.
Thanks fellas!'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
