Alright, so I got sick of seeing rust on S.U. There are three bad areas: around the mirrors and one spot on the left rear door. There are also areas on the bottom of the doors and rear fenders with surface rust. I started on the rear door and will update as I go on. Btw, this is my first real attempt at body work, so I'm learning as I go.
All pics (in larger format) will be added - - - here - - -.
Tools I'm using so far:
3/8" drill, 4" paint and rust stripping wheel, 7" grinding/cutting wheel, 5" sanding disk, Dremel w/ cutting/grinding wheels, rust converter, body filler.
Here's what it started out as: (it's about 2" in diameter)
I think I'm gonna be sick:
Took the Dremel and tried to work out the deep spots a little:
I applied some Rust Converter, but got called to work, so I haven't gotten much more done. I'll update as I go.
Although, this really does make me sick . . .
