The 93 GM "Tank of Justice II" (TOJ2)
    Wow. This weekend has been a blur.
    Moog sway bar end links are in. I powder coated the brackets.
    Then did spark plugs. Tell me, do think #5 had any issues?
    Put in E3 plugs and a set of MSD StreetFire wires that Summit and Jegs says will not fit Crown Vics. Liars. These were only $40 as well.
    Also did a coolant flush, installed the correct green t-stat housing. And fixed the fan to boot.
    And fixed the negative terminal. It was loose. So I installed a terminal shim. Hmm, thinking about installing the PI intake this weekend. We'll see.
    I couldn't install that belly pan. It did not fit. Front lip was about 4 inches too short. Hmmmm....
    The Tank runs geat now.
    Ka-pow!
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      lookin good!
        4 inches? need more bracket... like a 4 inch long one.
          #5 looks like valve cover leakage. I'd be more concerned with #3. I've never seen an Autolite with a U shaped bridge.
            +2
              #3 is a E3. #5 sits next to the thermostat housing which I did just replace a few weeks ago.
              And I'll get the approximate 4" bracket/panel tomorrow.
                H-pipe broke today at the flange weld on the passenger side. Friday will be three years to the day of install. You'd think aftermarket stuff would last longer than 3 years, while stock lasts over 17 years.
                Ordered Moog upper ball joints and hubs.
                All I need are struts, springs, and control arm bushings.
                I also need suggestions on struts and springs. I want to firm up the comfy-couch ride just a little bit.
                Any ideas?
                  I saw Motorcraft shocks on rock auto that were for the sport/air spring/performance package. Bought a pair for the wagon to use when I switch to air springs. Used the 5% off code.
                    Also my GM 93 sport rode great imho. That is why I want to bother changing over the wagon. A 93 should be easier as they had that as a factory option. I do not know what year they integrated the ride control into the main computer but 96 still had a separate module and 03 did not.
                      I dont have air ride. And I need to do the fronts baaaaaaaadly.
                        I was suggesting an upgrade.
                          Any ideas?
                          ...do you remember what brand the H-pipe was?......
                            Also the sport shocks and springs were nice in the front.
                              Walker. I already called and bitched.
                                no4 plug was waay wider than the rest
