If they're rubber bushings, did you tighten the lower control arm bolts with the suspension at droop or normal height? They should be done at normal height or the rubber will hold the car up somewhat. Poly shouldn't do that since the inner sleeves aren't serrated like stockers are.
Pesty's Crown
The spring was out of the pocket a bit but there is still about a 1/2 inch difference.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
drive through a few pot-holes/speed bumps to set everything securely?
Well it doesn't sit any different then before but it is allot stiffer. I may get 1/2 inch spacers to lift the back or cut down the front a half coil but I will wait for everything to settle out before I do. As far as handling I don't want to horse it around until I get it aligned. The only thing I can say for sure is that the speedo is closer with the 3.55's than previously. I have an appt tomorrow to get it aligned and I'm taking it the the 1/8 sunday so I can say for sure whether all this work is worth it.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Went to the strip today. Every ones times were at least a half second slow so I'm not sure what to say about my time improvement. I only gained .1 in the 1/8 from before with the stock susp. and open 3.08's. I was hopping for more but o-well. It was a good time none the less.
Originally posted by Pesty351 View PostWent to the strip today. Every ones times were at least a half second slow so I'm not sure what to say about my time improvement. I only gained .1 in the 1/8 from before with the stock susp. and open 3.08's. I was hopping for more but o-well. It was a good time none the less.
Good so far. It drives nothing like a box anymore. It feels a lot like my 03 PI.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
I got a ticket today. "Improper start from a stopped position". I guess I do need some M/T ET streets so I'm not spinning of the line. lol.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Sideways in first and second.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
