Yeah... headlights and parking lights go through that. That's about it.
+1, headlights and such.
'91 has (I think, it's been a while since I've looked at it) a smaller connector further down which puts it out of sight with the new style air intake. http://www.grandmarq.net/vb/showthre...l=1#post818392Vic
Thats a good idea if I intended to keep it.Originally posted by IPreferDIY View PostNFC what it's connected to, but if you're talking eliminating the plug altogether, one possibility would be keep the plug but add long enough pieces of wire to hide it.
hmm...Originally posted by gadget73 View Postpretty sure thats the header panel light harness connector. Useful if you ever need to remove the header panel for some reason.
Shows how useful that was to me at the time. lol circa 2015...
ThanksOriginally posted by sly View PostYeah... headlights and parking lights go through that. That's about it.
I think I will be going the delete route. The car has so much altered and added wiring (because of upgrades and such) that it is kinda pointless for me. Just an eyesore.Originally posted by VicCrownVic View Post+1, headlights and such.
Thanks everyone.~David~
There is a bunch of room inside of the fender but aside from that I dont believe there is anywhere do hide anything. We have to remember here that foxes have strut towers that can hide wiring.Originally posted by packman View PostI wonder if there is a way to wire tuck most of the wiring; kinda like what the Fox body people do? I have been looking at that lately since the engine is back out of the CV.
I have what I believe to be an awful amount of wires in the bay. It would be cool to make them go away but it would come with a ton of effort. Wiring things up nicely take a large amount of time.~David~
The header panel harness in a Fox car also lays along the frame rail where our steering box would be. They don't have less wiring, its just routed a little different. If you really took a look under the hood of either of my Foxes you'd be baffled with the amount of wiring in there, but its not quite as visible on first glance.86 Lincoln Town Car (Galactica).
Understood. I should probably focus on getting the car running anyways. Then maybe worry about aestheticsOriginally posted by 87gtVIC View PostThere is a bunch of room inside of the fender but aside from that I dont believe there is anywhere do hide anything. We have to remember here that foxes have strut towers that can hide wiring.
/\ /\ Truth
Speaking of aesthetics....
I axed the ugly salt shaker connector over by the air box/washer fluid reservoir....you know...this one:
and now:
And finished the Line Loc install.
Its visible underneath the master cylinder. Its bracket shape was based off of the factory brackets that aero and whale panthers sport for some wiring connectors.
I made up brake lines by picking up two more 98 to 02 NON abs front drivers side brakes lines from the junkyard and bending/cutting and flaring them to work with the hurst unit. All is good and the line loc functions!~David~
Inquiring minds want to know....
Have you undercoated the rear wheelwells?
Anything left of your rear tires?
Negative on roasting them.Originally posted by mitymerc View PostInquiring minds want to know....
I tested it the lame way. While front of car was still up in air (as I had to bleed the front brakes after introducing the LL) I tested normal braking function then applied brakes, held switch, released brakes and confirmed that the fronts were still holding pressure. Released switch and brakes released as well.~David~
I am expecting a dash cam vid w/cam looking backwards LOL
honestly the rear-facing fill and drain plugs are almost enough to warrant one. No drain and having to fill it from the other side where access is poor sucks.86 Lincoln Town Car (Galactica).
