the module is located under the dash above the gas and brake pedals. my manual goes through alot and shows it taps power from everything. there is also a scan tool that is used to do the message center and related tests/diagnostics.
My new 1980 Lincoln mark VI
they are vac operated. mine is the same way but, only after an hour they start creaping open.
Well I found the problem with the breaks, The main break line running front to back was already replaced, then I noticed on the right side of the diff there was no break line at all going to the break cylinder. So im going to order 2 new rear break cylinders and put new break lines across the rear diff and then the breaks should be back in proper working order after I bleed them.
The gas tank will be easy to change to, as the bolts are nice and clean and shouldent snap. As long as lincoln and grand marquis use the same size gas tank im all good, as the gas tank I am putting in is out of a 84 grand marquis. Both are carburated.
1980 Lincoln Continental Mark VI Signature Series
351 4 bbl, AOD, 3.08 open
duel exhaust with cherry bombs
get that sender replaced mang! i know i already told you that lol
Damn that sucks..~David~
well car is runnin awsome now, got the cherry bombs on to. Few exhuast leaks but still sounds good. if all go's well I will have a trip permit on it tomorow. Just won't be able to drive it in the night till I fix the head lights
looks nice. good to see another classic saved. did you ever get the message center thing sorted out?
