Sly's Panthers
  • sly
    replied
    Got the new wheels on the Mark...
    The old wire wheels are up for getting if anyone wants them. 2 are bent. one of the bent ones has the prettiest wires. one of the unbent ones has the loose wires. I'll let them all go for $200 + S&H (4 boxes @ 20 some pounds each). Just the bent ones? $20 + S&H. Just the good and round ones? $180 + S&H. The bent ones are bent at the lug plate and may be repairable.
    Leave a comment:
  • sly
    replied
    Originally posted by gabegt90 View Post
    you should a get a aero washer fluid bottle
    yeah... kinda tired of the current one sliding around. I will do this eventually.
    Leave a comment:
  • gabegt90
    replied
    3g looks good
    Leave a comment:
  • gabegt90
    replied
    Leave a comment:
  • 87gtVIC
    replied
    Nice work!
    Leave a comment:
  • sly
    replied
    2g-3g... I got my 3g from a t-bird. I had to drill out the bottom hole for the bolt to fit through (1/2" drill bit)... grind off some of the bracket to allow a little more movement to the slack side... as for the wiring... charge cable to the battery... yellow wire to the charge cable... green/red wire is cut off the 2g and soldered to the 3g... bolt in and go.
    I did have to get the 50.5" belt and use the 2g pulley. I will order some 51.5" (or something close to) gates 6 rib so I can use the original 3g pulley.
    Leave a comment:
  • marquisman
    replied
    nice! this might sound weird but, to this day, i have no clue on what needs to be done to install one. its all greek to me lol
    Leave a comment:
  • sly
    replied
    here's the pics of my 3g installed.
    the whole engine shot
    the 3g alternator
    the, now unused, 2g charge/sense wire fender connector
    and the wiring mess near the battery
    The white arrow points at the circuit breaker for the headlights and the blue arrow points at the sub amplifier power wire.
    the only thing left to do is order some custom gates 6-rib belts so I can put the larger pulley back on the 3g. I had to put the 2g pulley on and get a belt made for the large case alt to get it all working.
    Leave a comment:
  • marquisman
    replied
    suuuure... lol
    Leave a comment:
  • sly
    replied
    that greenery was at the in-law's place. My place doesn't have that kind of space.
    Leave a comment:
  • marquisman
    replied
    yea! i think you want some of our snow and cold weather lol
    Leave a comment:
  • zoomie
    replied
    im jealous of all that greenery around you
    Leave a comment:
  • sly
    replied
    3g alt is in... pics tomorrow when I have more energy... and light.
    Leave a comment:
  • sly
    replied
    yeah... buddy in CT got at least 15 inches of snow end of last week. I doubt I'll ever see such events here.
    Leave a comment:
  • 87gtVIC
    replied
    Texas and snow. lol
    Leave a comment:
