The tale of the 87' Colony Park
    drop mounts are an option too.
    It's probably ungodly expensive but the body line-based hood raising is something I've considered before and should look good.
      It does. I wish I could have bought that towncar. EFI 351W. Body was rough though. Not much left of the rear quarters.
        Nice. Please tell me you are installing it with those valve covers.
          Originally posted by SVT98t View Post
          Oh Jesus. I better step it up than.
          I cannot wait to see/hear this. Actually, I could probably hear this from my house.
          I think an M112 will make the Marauder easily keep up.
            An M112 and some woodgrain to keep up with the style.
              I think you should woodgrain the blower.
              08 Lincoln Navigator L - 233k
              03 Mercury Marauder- 63k
                Originally posted by svt98t View Post
                i think you should woodgrain the blower.
                this!!!!
                  No way in hell it's fitting under the hood. From my measurements, the entire pulley and all of the snout and possibly the very top of the blower will be sticking through. Looks like I may have to run a 3/8th intake spacer to fully clear the distributor. Should be interesting.
                  I need to figure out what accessories brackets I'll have to run. I have a fox w/p and crank pulley and they line up perfectly. 91 Cougar brackets and 97 Explorer brackets put the belt about an inch or so to far inward. Stock box pullies are about half an inch to far out. I'll have to go to the junkyard and grab some F150 brackets and see how they fit.
                    If so, dont cut upyour hood! Get another hood to put a hole in!
                      It's just a hood. I do have a spare. Also debating if I should even bother advancing the cam at all. Might just put it in straight up. But I may advance it 4*. I can't decide.
                        Flip a coin.
                        Or just advance it anyways.
                          On a spare hood you should put on of those bond-on cowls on it, the ones that are 2 or 2.5" tall, whatever you need. Bolt-on would be easier but I don't know of any bolt-on cowl scoops. At any rate it'll be nice to have to vent out the extra heat, i'm gonna get a cowl hood for my truck soon to vent heat and my Suburban.
                          I've been wanting one for my Lincoln too, wich I could do bodywork then i'd get a couple junk hoods and make one extending the stock raised center section like mentioned before, that'd look sick since the Lincoln's center section is more protruding than the Vic/GM.
                            Whoa!!! When did this happen? Getting all warm and tingly thinking about what that's gonna run/sound like.
                              there will be enough torque from that pump on top that advancing the cam is probably not neccesary.
                                Exactly my thought!
                                I noticed that this engine didn't have the oil chucker, just the bolt and washer on the cam. It's definitely never been apart before, I guess some engines just didn't get them?
