How many valve cover bolts does that have? Should post up some more pics!
1979 Ford LTD, barn find FTW
oOo it even has the original old school awesome air cleaner! What modifications have to be made to fit that in the LTD? What transmission is that?? This could be very interesting! should make some power too, especially if you went 4BBL! Even the 2bbl made awesome powerLast edited by Brown_Muscle; 12-18-2011, 04:14 PM.-Phil
Originally posted by flyb0t View PostOn an unrelated note, can anyone explain why my Grand Marquis is misfiring/bucking at speed? Literally everything on the motor has been replaced once (or twice) recently, and yet nothing is resolving this misfire/bucking idle/bucking-jerking while driving. Only things that haven't been replaced are the timing chain (which we checked and think it's still okay) and the TFI module, which we tested and verified working.
Originally posted by Brown_Muscle View PostoOo it even has the original old school awesome air cleaner! What modifications have to be made to fit that in the LTD? What transmission is that?? This could be very interesting! should make some power too, especially if you went 4BBL! Even the 2bbl made awesome power
As for the Mercury, Mercracer, I'll have to check for vacuum leaks. Weird thing is, it will will start okay, and idle okay, but then as soon as it starts to get moving, it starts to bork up. Is this symptomatic of a vac leak? Or is it something wiring related?1984 Mercury Grand Marquis LS (Daily Driver)
1979 Ford LTD-S (Project)
Originally posted by Mercracer View Post8 bolts for Cleveland vs 6 bolts for Windsor
...which is why I was asking. I can see 6 but I think snow is covering up the other two. If there are no other two, it's a Windsor.
They don't look like they're in the same arrangement as a Windsor, though (3 along the bottom.)Last edited by 1990LTD; 12-18-2011, 08:03 PM.sigpic
Originally posted by flyb0t View PostAs for the Mercury, Mercracer, I'll have to check for vacuum leaks. Weird thing is, it will will start okay, and idle okay, but then as soon as it starts to get moving, it starts to bork up. Is this symptomatic of a vac leak? Or is it something wiring related?
Originally posted by 1990LTD View Post...which is why I was asking. I can see 6 but I think snow is covering up the other two. If there are no other two, it's a Windsor.
If you look close you will see that there are 4 along the bottom and 4 along the top..... I have been working on these things for over 25 years...Last edited by Mercracer; 12-18-2011, 10:51 PM.
Originally posted by slymer View Postit could also be the PIP in the distributor going out. It could also be the noise suppressor capacitor on the coil going out. if enough noise gets into the EFI's thought process, all manner of crap will happen.
As for all the debate on whether or not it's a cleveland, sorry I didn't get the best picture, but I did count as soon as I saw it and there were 8 bolts on the cover. I will take more pictures as soon as I can.1984 Mercury Grand Marquis LS (Daily Driver)
Originally posted by Mercracer View PostI will bet you paychecks that it is a 335 series motor....
I wouldn't take that bet since I looked closer at the arrangement of the bolts.sigpic
Originally posted by marquisman View Postwill the suppressor dieing out really fuck with the EEC? iv never heard this before, very interesting though. wonder what would happen if you unplugged it, just to verify lol
Has the TPS been checked? Maybe it's turned digital instead of analog.
Originally posted by slymer View Postyes, it can if it goes out completely. You would however probably notice this on a stock radio because you would have the RPM based humming. Some newer aftermarket radios have filters for that noise. Older EEC is more susceptible to it than some of the newer stuff, but if the noise is larger than the hysteresis of the signals (the difference between on and off in a digital signal) it will create all manner of f'd up signals for the EEC to try to contend with.
As for the motor, I have a few more pictures I can put up directly. We found it doesn't roll over completely, however it does move. Thanks to the good fortune of all the snow (!) melting off up here, we may be able to put some progress forward.
And some progress on the LTD itself, with what some body work still needing done.1984 Mercury Grand Marquis LS (Daily Driver)
