MyGrandMarquis - Burgundy '83 coupe
This topic is closed.
should be on the driver side rocker cover. usally has the pcv valve in it.
Originally posted by marquisman View Postshould be on the driver side rocker cover. usally has the pcv valve in it.
Driver side valve cover lift off pcv vlave and move it to the side then shove funnel in the hole where it was and fill it up then set pcv valve back in there.
Originally posted by marquisman View Posti belive it was pantera who said *and i quote..."i want to remove my brain and eat it" lol2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Yep, figured as much. Wonder why earlier models didn't have a dedicated filler neck? Kinda strange. I jacked a funnel from the service bay, lol.
I can't believe how much oil this engine eats. When I bought the car the oil level was A-OK. But when I checked it earlier, it was 2 quarts low! I also wasn't expecting it to take more than a quart before the store closed, so I bought a gallon jug of MM Oil. So now it's like 40% MM Oil 60% unknown oil that Matt used. Well, better than being 40% low I reckon. And the oil that is in there is black as soot. -_- I wonder how old the oil REALLY is.
Following the every-3000-miles-from-new clock, the next oil change is due at 123,000 miles - 278 miles from now. Next oil change will be 1 quart Lucas stabilizer and 4 quarts of whatever I have laying around - most likely either Castrol GTX 10W40 or Castrol HD30. Might hurt my mileage a tad but I don't give a shit, as long as no more oil mysteriously disappears.1997 Lincoln Town Car Executive Series - Charlene
Saved from a tragic fate, planned mild restoration. Now with working heat, perfect for the cold winter!
Originally posted by pantera77 View PostYep, and of course it was in a thread about this same car....
Originally posted by Midnight Drifter View PostYep, figured as much. Wonder why earlier models didn't have a dedicated filler neck? Kinda strange. I jacked a funnel from the service bay, lol.
Was the motor rebuild by the PO?
What was done?
I have a theory or two as to where your oil is goingsigpic
lets see the rear main seal was replaced the valve cover gaskets were replaced but i see it starting to leak again from them time for new ones. the oil pan gasket was replaced. check the pan drain plugs might need new ones.
untouched shortblock except for the rear main?sigpic
nothing internal in the motor was touched.
Fuck new seals, this car is due for a new motor.
I changed the oil yesterday. 1 quart of Lucas Oil Stabilizer and 4 quarts of Quaker State "Itasca" SAE 30. So far, no death knock on engine startups. I'm pleasantly surprised.1997 Lincoln Town Car Executive Series - Charlene
Originally posted by 86VickyLX View PostWhy yes, yes it was he, who wanted to remove his brain and eat it. I think it involved the knocking engine thread that Matt made. I even had it in my signature for a while.
Best sig line ever btw.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
