Im going to bet that the previous owner might know something to do with that.
MyGrandMarquis - Burgundy '83 coupe
This topic is closed.
That's fucked up.sigpic
havent finnished that SEFI swap yet?
odd. might want to put electrical tape over the pack of wires there so it doesnt happen again.
Originally posted by 86VickyLX View PostThat's the coolant temp sender wire. that was ran there because right in the middle of the firewall is where he wanted it ran.
i advise you to replace the ignition switch X100000000000 in the merc. bad shit happens if it goes. i never replaced it which i should have it only is a $20 part but if it's original it probably falling apart which can lead to fires inside the steering column. replace it might even fix the starting issues and run smoother. i got a new one for my linc because i was already having issues like the car not always wanting to even crank over and getting stuck in the start position. when replacing it inspect the connector for melting plastic if it's melted buy a new connector shell they sell them brand new still.
Originally posted by MattsTownCarSS View Postremember i had his same problem of it not going out of high idle when i first did my 3g swap 85HPP said to hook the stator wire to the high idle came too.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
i belive it was pantera who said *and i quote..."i want to remove my brain and eat it" lol
Originally posted by 85crownHPP View Posthhhhuuuuuuuhhhhh??????
actually it was gadget that told me it. sorry pete
on the other hand nice to see new tires on the merc but it needs whitewalls desperately looks very tacky with blackwalls.
only about 1/3 as tacky as a yellow motorsigpic
Originally posted by 1990LTD View Postonly about 1/3 as tacky as a yellow motor
im painting my lincolns engine ford blue.
Stupid question worth asking Matt: Where's the oil filler anyways? I don't see that priminent 'ENGINE OIL' cap sticking out anywhere.
Same location as the later engines, I'm guessing? It's hard to see it in total darkness. <.<Last edited by Midnight Drifter; 12-10-2011, 08:24 PM.1997 Lincoln Town Car Executive Series - Charlene
Saved from a tragic fate, planned mild restoration. Now with working heat, perfect for the cold winter!
