VicCrownVic's 1991 Mercury Grand Marquis GS
lol, in the game "Sonic and Knuckles" for Sega Genesis if you are playing knuckles and don't move for a while he will take that stance tapping his toe waiting for the player to do something.Originally posted by sly View Post
If things are not dry enough to put back together I will see about working on the writeup tonight.Vic
Woah you guys had some water.~David~
Good to see the Merc was spared.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
Alright, time to probe your brain a little.Originally posted by VicCrownVic View PostGot something delivered for the car today, I wasn't expecting it until Monday.
It's not in mint condition but it's good enough for me.
[ATTACH=CONFIG]38920[/ATTACH]
[ATTACH=CONFIG]38921[/ATTACH]
What was involved in swapping over the 6-digit odometer?1997 Lincoln Town Car Executive Series - Charlene
Saved from a tragic fate, planned mild restoration. Now with working heat, perfect for the cold winter!
As far as I can tell there were no electrical connections that were submerged. I don't have a power seat on the passenger side, and even if I had ditch cornering lights the water wasn't high enough to reach those. All the under car electrical at the fuel pump and trans and such should have been high enough to stay dry. Other than a little squealing from the brakes, I haven't noticed any issues but will be keeping an eye on things.Originally posted by BuffaloRider View PostDamn dude, Michigan just can't seem to get a break. I'm glad the damage wasn't any worse.
I know what you mean about your heater core write up... I've been the same way about the timing chain write up that I said I'd do months ago...
As far as the writeup, it didn't help that my first attempt to compile my experience into one document was hosed when the file became corrupted... that won't happen again though.
Also trying to include as much accurate detail as possible makes the job itself quicker than documenting it. My wife always complains that I'm a perfectionist... pft, far from it, I just like things to be right that's all.
She'll say:
"Everything doesn't have to be perfect, you know?"
and my response:
"I know, but it should at least be right."Vic
Keep those build sheets. The electrical test sheet I have not seen before.
Originally posted by VicCrownVic View PostAt my place the water was down the next morning. Some of the local highways are still closed though.
My carpet is dry but the insulation/padding is still damp.
I also found some paperwork, while cleaning out the car, under the carpet and under the driver's seat:
[ATTACH=CONFIG]40653[/ATTACH][ATTACH=CONFIG]40654[/ATTACH][ATTACH=CONFIG]40655[/ATTACH][ATTACH=CONFIG]40656[/ATTACH]
It was a straight forward direct swap, but I don't think I have the part# for the 6-digit odometer.Originally posted by Midnight Drifter View PostAlright, time to probe your brain a little.
I got the odometer from mcninetyone, he could probably tell you what the part# is or may even be able to get one for you.
Once you have the 6 screws out to remove the face, pry the temp and fuel gauge up, then pull the speedo out of the housing.
On the back of the speedo the odo and trip-odo are each held in by two screws, and the motors that run them are held in by the plastic housing.
Be carefully prying the motor out, I didn't have any issue with the tabs breaking but they are 20+ year old plastic.
While you're in there make sure to replace the odo gears since they have most likely turned to crumbling wax if they are original.Vic
The electrical test sheet was under the carpet and padding under the front passenger seat. The sheet with the big block letters indicating different options was under the carpet and padding under the driver seat. The more complete build sheet was tucked in the thin metal seat cushion supports on the underside of the driver seat.Originally posted by Mainemantom View PostKeep those build sheets. The electrical test sheet I have not seen before.
I already scanned the documents to my computer but will be holding on to these originals.Vic
Well, considering my odometer doesn't work... :p
Thanks for easing my concerns a bit. Sounds pretty simple. Soon, my 93 will have Certified Calibration.
Actually (don't know why I didn't think of this last night) I could take a look at my spare 85MPH unit and get some pics for you.Vic
