Me and the electric metal glue gun don't get on so well. I just can't see it. I can torch weld, not amazingly well, but it comes out much better than MIG does for me. I can see the fire.
85.03 Crown Vic Coupe "CVGT"
Gadget, can't see even with the auto-darkening mask? I believe Scott has also mentioned the same issue... And yes, you are both correct, when MIG welding you want an external light source, and a good one at that - most folks wouldn't think it makes a difference given the intensity of its light is nothing compared to that of the the weld itself, but it does helps. I got these all-glass LED bulbs for the drop lights for that very reason, anything plastic will succumb from weld spatter sooner or later, the glass ones just don't care, and are bright enough to where you can actually see wtf you're doing.The ones who accomplish true greatness, are the foolish who keep pressing onward.
- Likes 1
I don't seem to have any issue with that and my mask. I just can't weld very good.
Don't have an auto mask. I don't have a welder here, and the Luddite I work with/for "doesn't trust them" so basically they are verboten. I probably shouldn't say I can't see it so much as I can't see anything else. I get one bright spot and have no idea where I'm supposed to be going. I have the same trouble driving at night. External light helps, but I still have a lot of problems with it.
Between that and the dead liner in the MIG at work causing wire feed problems, I get so frustrated with it that I only bother if I absolutely have to. If the stick welder wasn't such a pain to drag out, I'd try that. At least that doesn't have feed issues. No idea if I'd have better luck with that though. Never tried.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostIf the stick welder wasn't such a pain to drag out, I'd try that. At least that doesn't have feed issues. No idea if I'd have better luck with that though. Never tried.The ones who accomplish true greatness, are the foolish who keep pressing onward.
"drink a beer, grow a beard, cut it, grind it, weld it back"
Words to live by, gents.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Still trying to find a driveshaft yoke that will fit my stupid fucking transmission.
That and life is the major hold up.
Aside from the G'note of parts that need to be ordered.__________________________________________________
Put new weatherstripping on it. Found out that foxbody door trim from LMR fits perfectly on a coupe panther. https://lmr.com/item/LRS-20708A/1979...y-Weatherstrip
Got two new ball joints on the driver's side. MOOG of course. Need to get new struts and then I can put the new springs in it.
It's been unable to roll, so once it's able to again. I'm going to put it on a trailer and bring it down to the shop that's going to build my driveshaft. They can't find a yoke that will fit my transmission, so I'm going to bring it down there; so that they can test it. Since apparently it's got a Viper mainshaft. They are currently building the one for my truck, since that decided to wear out (F350 Powerstroke) and that's costing me $450. So hopefully the Vic one will be cheaper.
I haven't really been working on it since I'm away almost everyday during the week. It's also not interesting me that much, currently. But it'll be driving at some point soon.__________________________________________________
Mustang door seals are the same as 2 door Panther? Interesting. Wonder if that same stuff could be cut into appropriate length for 4 door models too. What did you do for corners, just miter joints and glue?86 Lincoln Town Car (Galactica).
In for pics and more info on how the door weatherstripping fit.~David~
Originally posted by gadget73 View PostMustang door seals are the same as 2 door Panther? Interesting. Wonder if that same stuff could be cut into appropriate length for 4 door models too. What did you do for corners, just miter joints and glue?
Originally posted by Mr Bean View PostHow does the weatherstripping fit around the top corner where on Panthers it's a sharp molded section?
Update:
Car runs and drives, is tuned for 8-12PSI. Big steam.
It's got a blown head gasket now, which is promptly blamed on my faulty torque wrench. But it should be fixed soon enough. I don't know if I'll drive it much this year, I'm barely home and the car still needs a good bit of work and lots of money before I want to show it off. Adam @ Pops Racing did the tuning. I towed the car out to his house in Rochester NY this past weekend. Stayed with the Ryan Snyder family which was quite the pleasant experience.
Me "So do you think it's at least a 12 second car?"
Adam "12 seconds? More like 10-11 second"
Me "Perfect, so it should at least do burnouts"
Adam "Uh.. Yeah.."__________________________________________________
Nice to hear from ya. Did the head gasket let go while being tuned?~David~
Originally posted by 87gtVIC View PostNice to hear from ya. Did the head gasket let go while being tuned?
So I just sent it.
I mean it wasn't that bad..
http://www.americanmuscle.com/door-w...-kit-7993.html - For anyone interested in the weatherstripping. Would probably take two orders $50 to get 4 of them for a peasant 4 door/sedan.__________________________________________________
