Fits well enough for me. These weren't very space hungry drivers, but they did want a "huge" port volume. If I would've went with a circlular port I would've probably been a little better off. And I didn't want to mess with making fancy shapes, I just wanted a square.
I bought a box!
that's what I'm currently using in my 93 (stock springs). The civi shocks (only option in the rear) will keep the float but will hold the road well as it will keep the tires from bouncing.
I know know the back end shouldn't bottom out whenever I sit on the car's trunk. That means I get to cut out some shocks here soon.......ugh.
I wasn't sure if the gas-a-justs were actually a performance improvement or if they were just expensive branding of the cheap monroe shocks.
Sounds more like springs. They are easy if you are doing the shocks anyway.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
it works off the shuttle valve. Not sure what the switch itself is called. It doesn't have pressure through it though. The shuttle valve moves and pushes on the switch to turn on the light. The shuttle moves only if there is some gross imbalance of pressure front to rear, basically meaning if you blow a line it moves and the light comes on.86 Lincoln Town Car (Galactica).
Don't know if you can just get that or not. It probably is exposed to some amount of pressure, but pressure isn't what actuates it.86 Lincoln Town Car (Galactica).
from what ive read that means the whole proportioning valve ate it. I have a temporary fix of jb welding the ass out of the sensor to keep it from leaking through the sensor and i have made silicone joints at all of the brake lines. Seems to be holding at least a bit bertter now.
If someone has a proportioning valve i would love to buy it form sonmeone
Junkyard?
Even if it is slightly crusty you can just cut the lines on the donor car real short and get on the nuts with a true hex head deep well, spin those mammer-jammers right off.Last edited by DerekTheGreat; 10-10-2016, 06:46 AM.1985 LTD Crown Victoria - SOLD
So more brake quandaries because apparently this whole system was dicked well before I got to it.
So I just used a metric shitonne of silicone and rebled the brakes last night and then went for a ride. Whenever I had some hard acceleration the brakes would come back to me, then when i was doing a bunch of loafing around the brakes would get squishier and squishier.
Today drivign to school (45 degrees or so) I had complete use of brakes. Felt like a normal cars should.
Whenever I am on the highway my brakes feel correct. Whenever I come off of the highway I have a couple of good stops before it goes squishy again.
Ummmmmm. Idk what is going on but I would like some help. I'm at my wits end with the damn brake system atm and if I wasn't so in love with the exhaust note I would be sending it to the junkyard out of frustration (well maybe not that far...)
Anyways, I've been teasing you guys with news of glasspacks, here are two poorly shot videos of my exhaust. Sorry I am holding the phone wrong, it is hard to landscape while driving.
https://www.youtube.com/watch?v=zpH5oIGdGKo
https://www.youtube.com/watch?v=wJyeP_bQaAo
