Buyer's Remorse (AKA "Hideous") - Giraffe's 1990 Grand Marquis LS
    That red wire. Does it have 12v? If so, does it have a fuse?
      That's the wire for that start switch I mentioned. A new Motorcraft solenoid is on the way. I'm thinking the solenoid went out before and the previous owner was too cheap to buy a new one. I hope. We'll see.
      —John
      1985 Ford F-150 XLT Lariat
        Definitely keep an eye/ear on that knock, otherwise i think it looks great. A good cleaning will definitely help though.
        -1994 Lincoln Town Car...always under construction
          I used to dump a can of "restore" in with every oil change. It seemed to quell the lopo knock.
            Is your knock present hot/cold/all the time?
              Never heard of that stuff. Is it anything like the Lucas oil stabilizer?
              I'm not sure. I'll have to check next time I run it. Out of town for Thanksgiving, so that'll have to wait until next week.
              I bought a new Motorcraft battery for it yesterday; it cranks on its own now. I just need the solenoid and I should be able to get rid of that stupid switch as well. I'd like to start daily driving it next week. I also noticed that is has a pronounced oil leak coming from somewhere on the driver's side that's leaking onto the cat making it smoke constantly. It's also dripping on the ground at a rate of about two drops per minute. There's so much dirt/oil everywhere that I really can't tell where it's coming from.
              —John
                Gonna grab these. I can get 100 for the price of two cards of three. Always good to have spares.
                —John
                  I usually suggest a stereo upgrade instead of magic potion in the engine. Fix the knock properly when it becomes a real problem with an actual engine.
                    Not a bad idea since the radio doesn't work. I'm going to look into acquiring a jy exploder motor soon, I think. Might as well have it ready.
                    —John
                      Engine Honey in a can will thicken oil and get rid of the knock or just run 20w-50
                        You think I could get a good sounding system with just four good speakers and a good aftermarket head unit? I've never messed with audio systems in any of my cars. I'd be happy with something on par with Ford factory sounds systems since the 2000's.
                        —John
                          Originally posted by Giraffe View Post
                          The spare is also useless. It looks to have been involved in a major blowout.
                          Wow...
                          '79 Continental Town Car
                          '90 Crown Victoria LTD
                          '94 Crown Victoria
                            Nice find on the regulator bushings.
                              For the source of the oil leak, my first guess would be valve cover gaskets. Make sure the valve cover bolts are not loose, I came across that recently.
                              If that's not it, my second guess would be the lower intake gasket. I would think this would be less likely than valve covers gaskets.
                              If the source is still not identified, check the PCV. The grommet along wit the valve will pop out of the lower intake and oil can escape in the fumes coming from there. If there is significant blow-by, enough oily fumes can escape and the oil accumulate to the point where it drips. Usually the tell-tale sign of that is an oily wiper cowl in that area. I would think this would be highly unlikely to be your source, but if nothing else is found this is the last thing I would check.
                              Another oil leak I have had in the past is the original oil pressure sensor/switch. That's toward the font by the oil filter, not near the area you describe. That should leak straight down, so not likely your culprit.
                                What Vic said. If it's that nasty i would take the car to town and pressure wash the motor and then buy permaseal rubber valve cover gaskets and a new lower Intake gasket set. Put a new pcv, screen, distributor o ring, and oil sending unit. Short of oil pan gasket that should fix a lot of oil leaks.
                                -Nick M.
                                Columbia, SC
