Nice work guys. Poor wagon looks like it has been sitting for some time. Going to be a cloud of debris behind it once you get it moving.
1989 Mercury Colony Park
I can hear the brake booster leak. shhhhhhhhh every time the pedal goes down.
one thing I will give hydroboost, never have to worry about that. The power steering pump makes random noises instead.86 Lincoln Town Car (Galactica).
Haha Thanks David! Yea it's going to be a mosquito fogger once I take it off the property and run it! That EGR Spacer is doing the trick. I stopped driving the car...October 2018? Due to the wasted rings. So yea lots of dirt and pollen. Needs a bath!
Yea we noticed that too..I scored a Ford booster for like a 96 Vic for $60 to my door. Brand new. I put one in my 1990 too so I could get rid of the big pancake. Zach did it on his 87, makes for a lot more room.
Hydroboost on my 05 Yukon I sold was nice and smooth. Pump did make noise randomly - ha that's true. Forgot about it.
Next is to clean everything out of it (storage locker), air tires up, replace booster, clean it so i can see out the windows, install a replacement radiator, adjust timing, install a better temp gauge...and drive it!-Nick M.
Columbia, SC
I have some sad news to report. As I was fixing the poor cat to H pipe flange exhaust leaks I singed my arm a little on the cat - that hurt a bit lol
But more importantly, the rear main seal has a good steady drip of oil out of it :-( No its nothing else but that only. I'm really bummed. And I am not taking a trans or engine out for a rear main with jackstands etc. Off to my local trans shop later on when they have time. I wonder what happened - it was replaced with a FelPro 1 piece. Still needs the exhaust fixed, i'm going to get some FelPro gaskets and get rid of the garbage ones that came with the replacement cats.-Nick M.
Columbia, SC
Bummer.
Even when you try to do thing properly you get punished.~David~
You put thread sealer on the flexplate bolts? If it's not the rear main seal it could be that. When I put the 306 in The Ice Car I didn't put thread sealer on those bolts, figured the leak was the rear main seal (although that engine didn't leak before) so I got everything I needed to do the rear main seal. Got in there and found it was those bolts.Vic
If the crank gets scratched when the rear main is pulled it will leak. Same if there is a wear groove. I'm not real motivated to change those seals unless its giving me trouble.86 Lincoln Town Car (Galactica).
Originally posted by VicCrownVic View PostYou put thread sealer on the flexplate bolts? If it's not the rear main seal it could be that. When I put the 306 in The Ice Car I didn't put thread sealer on those bolts, figured the leak was the rear main seal (although that engine didn't leak before) so I got everything I needed to do the rear main seal. Got in there and found it was those bolts.
That said, I dunno if we stuck thread sealer on the bolts. I know I didn't...
its coming from inside the bellhouse and not the rear of the oil pan?86 Lincoln Town Car (Galactica).
In my case (flexplate bolts w/o thread sealer) oil was running down the front of the dust cover/inspection plate. The oil dripped down as it exited and did not travel the length of the bolt into the bellhousing.Vic
huh, i'd have expected it to come out behind the bolt head, not between the crank and flexplate. Not sure I put sealer on mine either now that I think on it. Might have done loctite, which would seal the threads.86 Lincoln Town Car (Galactica).
Yeah, I was certain it was the rear main seal. Despite no leaks from the engine before the swap and none of the gaskets I replaced while it was out of the car looked like they needed it.
When I removed the bolt at the bottom of the circle oil came out (for maybe half a second, no more than a couple seconds) like I had removed an oil drain plug. It was at that moment that I realized I probably ordered a rear main seal for nothing. I replaced it anyway but it definitely did not appear to need replacing just like the rest of the gaskets I had already done (heads on up + oil pan). After the fact I read in the '91 service manual that I should have put thread sealer on those bolts. I've removed and installed AODs a half dozen+ times, but this was my first engine swap. Won't make that mistake again.Vic
Originally posted by Kodachrome Wolf View PostI was the one who put the seal in. It looked right when it went in.
I do not recall applying oil to the rear main seal ID...and I bet it’s spun....dry tight seal. Just like my 87 Taurus that someone installed incorrectly, causing it to do the same thing
Vic - mines doing that exact leak like yours. It’s coming from inside the bellhousing like gadget said. Neither Zach nor I applied any kind of thread sealer on the flexplate bolts - I never have in the past. Come to think of it they were damp threads but I don’t recall seeing any sealer on the bolts from the Explorer.-Nick M.
Columbia, SC
thinking about it, the holes for the crank don't go into the oil pan on the engine. The rear main seal is between the bolt flange and the oil pan so there shouldn't need to be sealer on anything.86 Lincoln Town Car (Galactica).
From what I remember, The one piece seal has to be installed in about 1/8 inch, not flush with the block. There is a special installation tool that makes it fit in that way. I remember reading if the seal is flush with the block, it WILL leak. WagonMan89 Colony Park
90 Colony Park
70 HEMI Daytona Convertible
