I used one the 90 degree ones in place of the s-shape in my 90, I'd assume you can go backwards with that as well.
My 79 Marquis
+1, rods can be swapped. Been nearly a decade so I don't recall specifics, but simple enough. Some tiny ball bearings in there that the rod rides on if I remember right.Vic
What's the right rivet size for door handles? Would 1/4 by 1/2 work?
1979 Marquis creamy goodness
Still haven't touched the rivets, started opening everything else up, never fails to get sidetracked. Have at least a shit load of man hours in this ( I am slow)
1. Headliner is out, the ceremonial dust foam a runneth. Was gonna do so myself but found a guy that will do that, my sunvisors, and two triangle pieces next to my back window for $400. Didn't want creases or to mess with adhesive.... this is gonna be a light color to match the camel interior
Will definitely look better then what I could do.
2. Got another wild hair up my ass and went after the cluster to replace with LEDs. Bandaid fingers.... speedo cable didnt want to budge ( also lest I forget the headlamp switch ritual)Have heard sometimes they don't work and you have to flip them 180..wondering how to test that before installing . Wonder what color, thinking of a amber/yellow light to match everything on the ride. Dont want to blind myself and know red is the best for night vision
3. Both front windows fully functional. Thanks for the brackets again WagonMan. Also Vic hooked me up with a window as I went aggressive with the drill bit. In my defense those regulator brackets were plastic. Shit started melting when drilling the rivets, hard to tell where I was.
4. Both front door lock acuators work now,..swapped out the rods on some NOS ones. Took a page out of Slys old posts and out a rubber piece on the rods to divert water.
5. New NOS taillight lens are in, NOS trunk emblem is on.
6. To do list;
Everything but the drag links in front suspension.
Fix my idle
Valve cover gaskets
Muffler and tailpipe
Put nos grill, lamps and bezels in.
Sure there is more.Last edited by Grand1; 11-09-2023, 07:40 PM.
I believe they are 1/4" rivets, you need a big ass rivet gun to put them in. Be careful doing it the amount of force you have to use can make the rivet gun(cannon? lol) bounce onto your new paint (ask me how i know...)-Phil
Oh fancy, that should make it easy-Phil
I’ve used SEM. They have a cleaner and adhesion promoter, basically a whole process. It turned out well on mine, and has lasted about a decade so far.-Phil
Dash is done, looks primo.
Gutted the front end , uppers were a pain, 21mm bolts on the top of the control arm....didnt know that.. Do lower control arms from later boxes fit 79's? They take the same bushings, but rockauto does not include lower or upper control arms under the 79. Same thing goes for sway bars, nothing is listed for a 79.
My lower control arm only has one hole (for end links)vs the three holes on later models. If they swap over, does that mean I could put a sway bar for later boxes on?Last edited by Grand1; 12-21-2023, 04:47 PM.
I got the old.control arms from 94 areo and they look identical. Wonder why no sway bar or upper or lower control arms are listed for a 79. Also RA has differnt spring selection for the 79....all constant rate.
Been reading other threads (something up with the search function on my end) just want to make sure before dropping $$$ on parts that may not interchange.
The frame didn't change up front 79/91, so I would assume a lower control arm would bolt on from an 80/91 car. What else has to change would be a try it and see experiment, but I suspect it would be pretty compatible. I know the springs are the same.
79 also had the overlap from the LTD II and I think some of the confusion in the aftermarket has to do with that.1990 Country Squire - under restoration
You can also use Aero front springs- they’re slightly stiffer than police springs but should give you ride height. I cut a coil off mine to lower it, but they’re a great, plentiful substitute-Phil
