I couldn't decide if this would fall under electrical or interiors but I see a sticky for window motor related stuff here so I'm going here.
My driver's side window motor 'died' on my 87 and I have my old working ones from my 89 CV still.
I say 'died' because I pulled it out, hooked it up to a battery charger to test it out of the car and it spun fine in both directions. I'm guessing maybe the motor has gotten weak and doesn't have the 'umph' to pull the window up/down anymore though it looked and sounded okay..
Not wanting to throw a potentially bad motor back in and having a known working one on my bench from my 89, I decided to regrease it throw that one in instead. The 89 is the smaller motor housing vs the 87 with the larger motor. I took a quick look and they seemed to have the same mounting spots bolt wise.
After getting it into the door, it turns out that only 2/3 of the bolts line up to the mounting points (The ones at 9 & 3 o'clock). The bolt at 6 o'clock is off by maybe 1/2 an inch? I don't plan on drilling any extra holes in my door as good ol' mother nature is doing its damnedest already with that in rust.
The motor housing and assembly are completely different so there's no way to swap the 89 motor onto the assembly for the 87 so the mounting bolts line up.
The window seems to work fine with just the two bolts but I figured I could use some other opinions on running it without the 3rd bolt in there. The door is still apart for now as I'm also working on some rust treating.
Thanks!
Thanks!
