I am tired of telling people there has to be!
    Its definitely road related. If you live somewhere that isn't full of potholes and speed bumps, they last longer. If you live somewhere that causes a lot of suspension motion to happen, they wear out faster. When they wear out, replace them. DOn't drill holes in there or anything like that. The car is nearly 30 years old. If it needs a suspension part, feed it. If you've never given the front end a good going over, now would be the time.
      Rear end too. Once the bushings start going out your ass end will start to sway back and forth and generally wander wherever it wants to.
        Speaking of rear ends, when I purchased the car the rear end was making all kinds of noise.......turns out the rear axle/bearings were shot...I was fortunate, I put in axle savers and the rear end was returned to normal with no other problems. I will however take a look at the front end when on the lift to check those Zerk fittings.
          tried those on my car, they puked oil constantly. Gave up and replaced the axles and put stock bearings in there. Problem went away.
            How do they work? Are they just oversized bearings or what? I've never dealt with them...when an axle has a groove worn into it I put a new axle in.
              Its a bearing and seal assembly that moves where the bearing rides outward about 3/4" on the axle, basically where the seal normally sits. The seal on the repair bearing is built into it, and moves that outward too. The problem with mine is that the axles were crappy enough out where the new seal sits that it wouldn't quit leaking oil. Maybe if you had decent axles or spent some more time polishing them it would work better.
