Before the suspension, I heard some bubbling in the cooling system....it looked like a mixture of Yoohoo and diarrhea... thankfully nothing in oil. At the same time, drips out of the freeze plugs....after removed garden hose....basically small hand fulls. Only way to get most out is with the freeze plugs out. Put the rubber bungs in, when it's time to take the block out, it will be done proper. Two bottles of Thermocure, and no more rust in the cooling system.
Now if I had one mod to do first, it would be the headers...it just breathes and throttle response is on point....not to meantion the deep rumble. I also put a recurve dizzy in with a new throttle cable...that gets the tires screeching. Some engine bay cleanup as well.
Finally got around to putting in a shift kit....those smooth shifts was getting rough on the trans. Was having some miss at some gears. Transgo had a pretty straight forward kit with instructions. Messed with my vacuum modulator and tuned it accordingly. C6 back in business.
