For a couple years the speedometer cable has been making that annoying grinding noise. Since the '88 was in for other work today, I had a new cable put in. Seems that the noise is gone, but the needle still has a little bouce while under 25 mph.
Anyone know what can cause the needle to bounce? I'm just looking for some info on how the speedometer works in our cars. Thanks.
Justin
Justin
i listened to the motor and set my cruise based on revs
Then just drop some gear oil down that sucker and it should go away.
