Well, I started hearing this loud noise when starting my car. It is very loud and reminds me of when my belt tensioner started going, a real loud vibration/whining. I replaced the tensioner last year but didn't do the idler at the same time cause I suck. So I just assumed that it was the idler and replaced it today(5 min.). Let's just say it wasn't the idler .Well while the belt was off I was looking for loose shit, and the power steering pump pulley had a bunch of play in it, I can push/pull the pulley/shaft in and out about 1/4-1/2 inch. I doubt there should be that much play, so I'm guessing I have to change the pump. $85 for re-man., $15 at the junkyard. I'm thinking of going the junkrard route, since it's so cheap. Is this a PITA? Someone mentioned flush the system, it may help it.
Has anyone replaced the pump? How hard is it? Has anyone had a similar problem and the flush fixed it? I know I flushed the system when I replaced the steering box and that wasn't that long ago so that doesn't look too promising. Also : I know they changed the P/S systems in the Panthers and that they have different fittings. My car is a 1993. Which years would fit and what is the most recent year that would fit?
Thanks in advance for any help anyone can give, Thank You
