I think I've hit this point and I've only had my car a month. I'm not sure how much longer she will last. Her interior and engine are good, but the rest of her seems to be falling apart. And fast! I've spent $400+ in this past month to fix the rusted power steering fluid leak, which included the return line, some newer used tires, an oil change (had a coupon for $15....couldn't beat that!) and I still need to get my idler and Pittman arms fixed, possibly some new brakes, an oil pan to stop mine from leaking and EGR stuff. I paid $1,300 for her. 1995 GS with 70,025 miles as of today. Her age seems to be really playing against her because a lot of things need to be replaced and now, when I turn, there's a very loud creaking noise she makes. Any slight movement in the steering wheel causes the noise and you can hear it with the radio on as well. I'm a broke college student and I couldn't address some of this stuff earlier because I didn't have the money and still really don't, so I think she actually got worse. I've been thinking of not putting anymore money in her and ride out the summer as is, but I'm not sure if she can even do that now, at least not safely without stuff breaking. Some people are telling me I should sell her ASAP to save some money, but even that doesn't sound feasible and if I get $1000 for her, I still can only buy another "junk" car, so to speak.. What do any of you think? There's another post on here by me with pics of her and underneath her body.
When To Stop Putting Money Into Your Car?
You have to take an educated chance.
Say you fix the current issues. It could run for quite some time without having any problems and save you money in the long run.
But what's to say all that will fix it. It may not. Then you're out money and have a broken car.
I'd drive the piss out of it and save your money. These do last a while if you take care of them. My 93 has 216k and I drive it daily, up the road in Buffalo, NY. It's quite solid as well.
I don't know what your mechanical abilites are, but we do (for some odd resason) have a ton of members from Ohio and the Cleveland area. If any of them could help you out repairing your ride, that would be hugely beneficial. If you do go that route, rockauto.com is your friend. Lowest price on everything. They sponser our site and even have 5% discount code in available under the "Online Vendors" thread.
Doing work yourself saves you TONS of money, and you (should) gain a better understanding of your vehicle.
If you do sell it, you just wasted more money on tax, title, registration, inspection, etc. At least get your moneys worth out of it.
Just my two cents.
03 Mercury Marauder- 63k
I would think that the majority of your $400+ was the tires? If so that's routine and any car new or old uses up tires.
Idler/Pittman arm should be no more than $50 from rockauto if ya do it yourself (very easy).
I'm always for keeping an old car around and running over buying new. Nickel and dime parts are cheaper than a car payment. Just my opinion.1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
My idler arm was $11 through RA.
Some of us have not been wise enough to ever reach that point. I used to tell people I was into my car for about 10 grand, but its probably more like 15 now, and thats just a guess. I don't add up the receipts, its too depressing. I just drive it.86 Lincoln Town Car (Galactica).
Those noises you hear could very likely be cured once you replace those front end parts... These are generally good cars, once you take care of the pressing issues it may be fine. This is a gamble you take with any used car though. You could have the windows quit, the intake blow up if its not all or partially aluminum, the axle seals could start leaking...
But again, any used car could have needs of similar cost (or worse) spring up. If you like the car otherwise, I'd stick with it.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
old cars need maintenance
new cars need payments and higher insurance premiums and maintenance
These are reliable cars, even consumers reported then a reliable. As everyone said, any car will cost you money. If you do not need a car, sell her and save your money and concentrate on a degree. If you really need a car then you probably have something decent, based on these being cars that are made to last. Luck still comes in to it no matter what the brand or model.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by Lincolnmania View Postif its got tits or tires it's bound to give you trouble
When I shell out $400 buck for tires, I think that's only one payment on a new car. I don't count up my receipts either because it costs money to have vehicles. Any vehicles. In the long run I go months (maybe years) without a major parts purchase. So that whole time I'm not paying car payments, I'm saving. Then when it's time for a big purchase, it doesn't hurt so much.
You can put me in the catagory of keeping the old car as long as I can...!
I'd rather be a failure at something I love than a success at something I hate.
George Burns
Never. Or I guess I would say only when the price to fix it is more than the price of buying it new the year it was released.
It can be especially frustrating to buy an older car that hasn't been maintained as well as it could have, because then you have to catch up on the maintenance and fix everything that needs fixed first, but once you get it all taken care of it'll start paying for itself... I hope...
I like to categorize repairs for these older cars as either being urgent or something that can wait for later. New tires would definitely be something important, but I'm also not going to shell out money to replace the door lock actuators or new headliner until I have money to spare. It wouldn't be any good for me to have a car with new goodies sit in my driveway needing a $1200 transmission rebuild.
It just depends on what you can afford and are you willing to.
I've been driving my 1996 CV LX daily for seven years now. I bought a new car (2012) this springs in anticipation of replacing it but as strange as it sounds, I'd rather drive the Vic (or maybe that isn't strange at all). I've actually been thinking of selling the new car...
