Hello all. I just bought a 1996 CVLX, and when turning the steering wheel, it feels like every 90 degrees there is a "notch", if you will. He says it's the sector shaft, what is this?
Steering wheel has sections in turning ability...
The sector shaft is the shaft that connects your steering column to the steering box. It has a universal joint in it that allows the column to be at a comfortable angle to the driver as it enters through the firewall. If the universal joint in your sector shaft is going/gone bad, it certainly could cause the symptoms you describe.
2000 Mercury Grand Marquis GS HPP - SOLD
Wore out the cam chain tensioners and jumped time at 176k miles.
I'd take a look at it under the hood and try to wiggle it near those joints, or have someone turn the wheel for you and look for any funny business.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
