Oh - and a trick that might work - get two BIG hammers and smack opposite sides of the center link around the stud simultaneously, it will eventually fall out on its own. How fast 'eventually' is depends on how much you have in common with Thor.
Help! One wheel steering
ball joint press.
Originally posted by 85crownHPP View PostOh - and a trick that might work - get two BIG hammers and smack opposite sides of the center link around the stud simultaneously, it will eventually fall out on its own. How fast 'eventually' is depends on how much you have in common with Thor.Originally posted by sly View Postball joint press.
1995 Grand Marquis GS - 156k miles, three-tone until I find my paint
1990 Toyota Camry DX - 211k miles, someone else's future barn find
1994 Saturn SW2 wagon - wife's car
Originally posted by SVT98tI'll make it fit.
I own hammers.
One time my steering box broke of my trucks frame.
Yeah that was fun__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Originally posted by rezwrrd View PostI heard about the hammer trick on CVN, but I'm not too keen on it since I don't plan on replacing the center link right now. I don't have a lot in common with Thor but I'm sure I could still find some way to bugger it up. I'll try a press before anything else, thank goodness for parts store loaner tools.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by JeffBoudah View PostA tie rod/pitman arm puller will get that out.
I got the stub out fine with the press, but now I messed up something else. I was using a cheater and snapped off my wrench.
The puller is flared at the end so it won't take a socket, and the box end of my 11/32 wrench is stuck on there. I can't even take the damn thing off. It's starting to round off just using the open end of the same wrench, and it doesn't help that in desperation I tried using the vise grips. I don't think I'm going to be able to get my deposit back on this one.
I own hammers.
Looks like MANY front end parts need replacing - that is some serious rust there!
I would think you'd be able to file down the flaring to get the wrench piece off and fit a socket on.
This is the only way I'd try getting more leverage out of a wrench:
Here's the grinding method I was talking about:
I've seen pics of people cutting into the Pitman arm from the side, but you risk going too deep and messing up the shaft.
You can try hitting the Pitman arm with a hammer while it's under pressure from the puller, but you risk messing up the bearing. Mine took a lot of abuse before I resorted to the grinder, but next time I would skip the hammer.Last edited by IPreferDIY; 06-16-2015, 02:50 PM.
Originally posted by miamibob View PostLooks like MANY front end parts need replacing - that is some serious rust there!
Originally posted by IPreferDIY View PostI would think you'd be able to file down the flaring to get the wrench piece off and fit a socket on.
I own hammers.
I would agree that the stabilizer bar bushings should be replaced. Here's what happens when you let them get too far:
