Thx guys. I am gonna take it to an old friend that's a former ASE Master Tech that I just reconnected with and have him check it out. He said he needs to check out the high side as well as the low side and will go from there. I'll keep you guys posted.
A/C is fast cycling but still cools only while driving
Sorry I can't help you with A/C. I removed mine.
03 Mercury Marauder- 63k
Originally posted by sxcpotatoes View PostA/c is for pussies (and the elderly, so they don't die).2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Indeed. And mine is currently broken. I'm not happy about this.86 Lincoln Town Car (Galactica).
That sucks. The air on my S10 is shot, but I hardly drive it (and certainly won't on a super hot day ).2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Look, A/C is a luxury. Until global warming causes it to get so hot that many areas of the world ARE unlivable, that you WILL die no matter where you are in that region from the heat (no matter how much water you drink, etc), it's a luxury.
What did people do before a/c? How did they survive? Probably 90% of your life is being uncomfortable. I don't have A/C in my house. Not even putting the window units in this year.
Having A/C probably contributes to a lot of dehydration and heat stroke, etc. Because you're comfortable, you don't drink enough to be fully hydrated, THEN you go out somewhere, and maybe your car or the outdoors or that place isn't air conditioned. And maybe you're sweating, or you're outdoors and doing physical activity. Well, when you sweat, you need to drink at least a litre of water an hour to rehydrate. You need salts too, eventually, which is what those fancy electrolytes are in gatorade.
But you didn't bring water, or start off fully hydrated, you're very quickly dehydrated, because your body can't cool itself and you get heat stroke and/or die. Because you trained your body to expect "comfortable" temperatures everywhere you go. I think repeated cycling between indoors (A/C) & extreme heat can screw up your body too, and cause you to pass out or throw up or something.
I work all day in a warehouse with no AC, just fans pulling heated air off the back paved lot. If the system breaks down, I work in what amounts to an oven with 6 foot thick concrete walls that really holds the heat. If its 90 outside in the warehouse, its a solid 120 in the cell. I don't wish to be uneccesarily uncomfortable in my time off. I work so I have money to afford things like AC repairs and to pay the electric bill. I use the AC at home a lot less than my parents (specifically my stepdad) but when its so hot your balls sweat without even moving, the AC goes on. Either that or I have to sit around naked all day with a fan blowing on my junk and that tends to be offputting to the other people in the house.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI work all day in a warehouse with no AC, just fans pulling heated air off the back paved lot. If the system breaks down, I work in what amounts to an oven with 6 foot thick concrete walls that really holds the heat. If its 90 outside in the warehouse, its a solid 120 in the cell. I don't wish to be uneccesarily uncomfortable in my time off. I work so I have money to afford things like AC repairs and to pay the electric bill. I use the AC at home a lot less than my parents (specifically my stepdad) but when its so hot your balls sweat without even moving, the AC goes on. Either that or I have to sit around naked all day with a fan blowing on my junk and that tends to be offputting to the other people in the house.
Originally posted by sxcpotatoes View PostWhat did people do before a/c? How did they survive? Probably 90% of your life is being uncomfortable. I don't have A/C in my house. Not even putting the window units in this year.
Originally posted by sxcpotatoes View PostHaving A/C probably contributes to a lot of dehydration and heat stroke, etc. Because you're comfortable, you don't drink enough to be fully hydrated, THEN you go out somewhere, and maybe your car or the outdoors or that place isn't air conditioned. And maybe you're sweating, or you're outdoors and doing physical activity. Well, when you sweat, you need to drink at least a litre of water an hour to rehydrate. You need salts too, eventually, which is what those fancy electrolytes are in gatorade.
But you didn't bring water, or start off fully hydrated, you're very quickly dehydrated, because your body can't cool itself and you get heat stroke and/or die. Because you trained your body to expect "comfortable" temperatures everywhere you go. I think repeated cycling between indoors (A/C) & extreme heat can screw up your body too, and cause you to pass out or throw up or something.1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
Update...
I still have not had this problem addressed with a mechanic but I did notice over the past few weeks that the fast cycling seems to be tied to the idling problem I am having right at start up. Here is what happens..
Scenario 1: I start the car, it revs up for a sec and settles down and holds a steady idle just like it should... a/c runs fine, gets cold, no fast cycling. Great!
Scenario 2: I start the car, it seems like it is struggling, I tap the gas a few times within 2 sec of starting and it 'catches', revs up and settles down just like above and runs the a/c proper. Great!
Scenario 3: I start the car but it struggles and unless I rev it up, the car dies (and will so repeatedly until I drive a few blocks), even if I rev it up several times it still struggles to hold a proper idle... a/c fast cycles and continues to do this even after I drive 5-10 min down the road and the car is now holding idle.
Some have mentioned the IAC may need changing. I did take it off and cleaned it out with MAF cleaner and it 'seemed' to help but not for long.'01 Mercury Grand Marquis GS 4.6L
'01 Ford Mustang GT 4.6L
