Window wipers are retarded
    Ok this is the deal....When im sittin still the wipers are fine as i increase speed they wipe harder until they smack the windown trim and get stuck and i have to push them to un stick them so they can continue wiping.. Why would they do this and what can i do to fix them.Thanks for the help in advance.
    The Best
    i think this is cuz as u increase speed, ur also increasing the voltage out put by a bit? and i think you can pull the arm off the shaft and move it a couple splines back.
      Mine do that too while driving, but they don't get stuck. Might be a wind thing also.
        So i can pull the arm off and move it back a ways? That will stop it from goin off the glass?
        The Best
          i have the same problem.......my wiper transmission is worn out........it has a retail price of $59 from ford. i have the part at work. i need to put it on my car
          scott
            look and see if your wipers park all the way down. if it looks like they could go further, pop them off and set them down further. Dont ask me how though, its some clip you gotta pop out, or something...
              Here is the sollution, short of the regulator for the wiper motor being bad. My wipers did much the same thing a year ago, put then I replaced all of the parts stated in the pic. I got it at dealership cost for about $40, so add whatever merkup on that and thats how much it costs. I don't know if Ford has discontinued that part yet or not. I also showed where the clip is and how to get the wiper arm off.
              Sorry for the huge size, but I figured it'd be easier to read and understand.
                Thanks!
                I need that too, lol
                  Mine did that, then the spline wiped out so the arm wouldn't even stay in sync with the sloppy ass transmission assembly. I currently have one arm (passenger side) on the car and RainX is my wiper. I need to get the transmission assembly and new arms for mine so it works like it should again.
                    Thanks alot for the pic Blaze i will get on top of this asap
                    The Best
