I was wondering if it would run ok to swap parts in i guess you can say stages?
What i mean is, I know someone with a 87 mustang that swapped their heads\cam\intake and they still have their heads which only had about 15k miles on them. Can i swap just the heads and intake and run on stock pcm?
Also they have stock pcm With speed density, but i'm pretty sure i would have to change the cam since the firing order would change. I am going to pick that up from him as well and search for a HO cam somewhere.
Edit: I forgot to mention, i have an 87GM 5.0
