Ok im replacing my a/c belt, not the alternator belt ive already replaced that one. My question is this, due to the placement of the fans pulley i cannot get the new belt past i to get to the rear crank pulley, do i need to remove the fan and fan pulley to put the new one on?
Need some help please!
you have to take the alternator belt off to replace the ac belt......no need to remove the fan
it's a game of violent chess with the belts on these carssigpic
watch the edges around the fan shroud. They may get mad at you and cut you.
belts are blindfolded one-handed stuffPete ::::>>> resident LED addict and CFI defector LED bulb replacements
ok first off hatninja, fuck you, my dad isnt alive anymore to help me with these things. and second off, i figured it out but im just going to run it with the alternator belt only, the squealing noise when it started cold was the smog pump, which i dont need anyways and the a/c doesnt even work lol.
Clam down guys.~David~
sorry
Originally posted by 88grandmarquis View Postok first off hatninja, fuck you, my dad isnt alive anymore to help me with these things. and second off, i figured it out but im just going to run it with the alternator belt only, the squealing noise when it started cold was the smog pump, which i dont need anyways and the a/c doesnt even work lol.My wife and I.sigpic
There are just 4 bolts to remove the fan. I always have trouble realigning the fan after taking it off, but the aftermarket clutch was more intelligently designed
The fan shroud has just 2 bolts. I usually lift the shroud, and the fan, out together; but sometimes I can put in the shroud first and slip the fan in behind it.
yup, just loop the belt over.86 Lincoln Town Car (Galactica).
