Piotr's 359ci Windsor Build
    You are going to be hating life with the single plane intake and a 4,000-pound car....the Stealth would be the best choice, the Perf RPM (non air gap) second, as long as you run an open 1" spacer...
      I'll deal until I get a tko 5 speed. I got my eye on a couple 3500rpm stall converters in the mean time. I want to see how light I can get this car with out it looking stripped, we will see how she does.
        picked up the stuff from my machinist today. I'll be prepping and painting it tomorrow and maybe check the bearing clearences with plastigauge if I got time. I promise you guys pics!
          Pics for all you fools....
          I hate waiting for paint to dry....
          depending on how spunky I feel I might try throwing the bottom end together today.
            minus the back seat, my car does not look stripped, if i reinstalled the air vents it would look complete. just leave the headliner and trim in.
              ohh purdy motor
                Originally posted by lincolnmania View Post
                ohh purdy motor
                x1
                  yep, its come a long way from that rusty crap we got pulled from that f-250
                    yea had we seen it's true nastyness we prob would have got the motor out of that 72 ltd lol
                      hehe... late night in teh garage for me....
                      Got the motor about 85% done. Top end and bottom end are assembled. Intake is on, got the oil pan painted and installed. Just need to put on the timing cover and get a dizzy and a macho carb. I gotta drill my new vavle covers and put the breathers in. This thing is coming together nice and I'm proud to say I did it all by myself but I have a lack of confidence where I think its gonna sieze up or blow up when I run it. Hopefully that doesnt happen! Pics tommorrow mornin, I'm too tired now.
                      Also got my fuel pump and the first part of my gauge pack. Auto meter ultra lites.
                        Sweet man! You have more balls then me, I think I have enough worked up to do the top end but to assemble the bottom end is awesome! I hope she works great for you.
                          You'll be OK. When I built the first motor for my Lincoln I was afraid it would blow up too, but it was OK. Bottom end assembly is not hard, just as long as you check the clearances and have everything in spec. There's definitely a feeling of pride in firing a motor that you know you assembled yourself and it all works just as it should.
                            do you have an FPR? Holley's don't like more than 7psi, and if yer fuel pump is anything like a GM fuel pump it'll be cranking out over 9psi at idle - Holleys don't like 9psi at idle. I put an FPR in my truck and dialed it down to 5.5psi, made great difference. Also, does anyone make spreadbore intakes for Windsor engines? Cause Holley has the 4165 carb which is a spreadbore double-pumper, they also have the 4160 which is a spreadbore vacuum secondary... both can be had in 650, 750, and 850cfm airflows IIRC.
                              The pump I bought comes with an adjustable holley FPR. Its the summit fuel pump which is a rebranded Trick Flow one. I have a square bore intake already, so no spread bore carbs...eww
                              4160 is square bore IIRC... I have one on my old merk. 600 vac secondary.
                                90% done new aluminum valve covers, stainless hardware, oil pan, tons of stuff... arp bolts all around. Enjoy
