Originally posted by 1987cp
View Post
best readily available 302 to start with
Originally posted by 1987cp View PostI was going to say, get a shortblock from FordStrokers, and heads and cam from Larry's nemesis, and few people on this site will be able to get near you.
After research it seems like the one that would make the most sense is an explorer motor with some bits swapped out (cam, maybe rockers..what else?).
turns out quality aftermarket stuff is way, way more than i want to spend. for the price of a set of trickflow heads I could almost buy a complete explorer motor.sigpic
whats this about a build mrltd did on an explorer motor in a wagon? linky?
is the bottom end any different? i know i need a box specific oil pan but i'm curious if the internals are different in construction.
how about the front engine stuff?sigpic
timing cover has to be swapped cause the exploder water pump is weird, the oil pan and pickup have to be swapped, need an oil filter adaptor from ford, block is the same.
mrltd has a 96 explorer engine with a comp cams xe264 and 24 lb injectors
different ECU for the 24lbers?
I was recommended the e303sigpic
Originally posted by 1990LTD View PostAfter research it seems like the one that would make the most sense is an explorer motor with some bits swapped out (cam, maybe rockers..what else?).
found a 96 explorer for parts...350...i hope it's not that stupid fucking cologne v6sigpic
why the filter adapter? can't use an explorer filter?sigpic
Originally posted by 1990LTD View Postwhy the filter adapter? can't use an explorer filter?
that it?sigpic
Originally posted by Mercracer View PostAnother reminder to everyone that these are now obsolete from Ford. Stock up while you can. The same thing goes for many of the other little things we take for granted.
