not really since its still a Chryco product. I'd just love to see a 50s Chevy with a 383 that was not built out of SBC parts under the hood.
CFI to CARB-Advantages, Disadvantages
Originally posted by Crownvicman289 View PostVacuum line on the front of the parking brake or brake brake? The line leading to the can that's on the parking brake is the parking brake release, but the line coming off the brake pedal is for your cruise control.Originally posted by Crownvicman289 View PostThat sounds like the switch itself is leaking for the cruise control. Real easy to swap out.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by gadget73 View Postnot really since its still a Chryco product. I'd just love to see a 50s Chevy with a 383 that was not built out of SBC parts under the hood.
For instance, stroke the 351W out to a 3.85 stroke (a common 393W if you bore it out to 4.030) but then bore it to 4.060 and brag about your "399W"
Originally posted by Merc302 View Postive got a fabrication buddy, and i can go pick up a 350 shortblock for 150 bucks. but thats too much work for me between work 6 out of seven and school 5 out of seven.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 85crownHPP View PostWhats this?? there's no vacuum switch or vacuum anything for cruise control around the brake pedal... on boxes anyway... or any panther afaik, 'less I missed something on aeros+ Ive been in.86 Lincoln Town Car (Galactica).
whaaat?? it must be way up there... I don't remember seeing one when I wired in my 3rd brake light. *inserts foot in mouth*Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 1987cp View PostGuess I wasn't clear. The guy I talked to said you don't need fabrication skills to bolt in your SBC, just a drill bit. In fact, he reported running Chevy spindles on the front and a Chevy 12-bolt/four-link out back on Panthers with little trouble. Don't remember what he said about tranny crossmembers, though.1985 Mercury Grand Marquis ls-302 CFI
Carb swap planned .
c90 heads
475 lift cam
Weind stealth intake(looking for reasonable air gap or manifold for 2bblsidedraft)
Built aod(want c6 tryin to fin vac mod model)
331 stroker kit
Work in progress
Originally posted by 85crownHPP View Postwhaaat?? it must be way up there... I don't remember seeing one when I wired in my 3rd brake light. *inserts foot in mouth*2012 Mazda5 Touring | Finally working on the LTD again!
There are two deactivation switches for the cruise control. It's hooked up to both the brake lights and has the vacuum dump. The cruise goes into standby mode when you tap the brake pedal (from the brake lights), but has a mechanical vacuum dump in case something goes to hell.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Interestingly, the later cars don't have the vacuum dump. They have a pressure switch in the master cylinder to break power to the cruise circuit as a secondary failsafe. The vac valve is sort of nice though. If you ever blow the fuse for the brake lights for whatever reason, the cruise will not deactivate when you tap the brakes. It will purge if you push down on the pedal a bit tho. Mildly scary when the cruise stays engaged when you don't expect it to. BTDT.86 Lincoln Town Car (Galactica).
Later being what? I'm pretty damn sure my 91 has the vacuum dump on the pedal, because I've been under there several times when I had to replace the brake light switch.Originally posted by gadget73There is nothing more permanent than a temporary fix.
:lol: '91 being the last year ever of "proper" Panthers .... I'd say that's pretty "later".
The only thing I'm really certain of is that I don't recall seeing any vacuum thingies going to the service-brake pedal on either my '79 wagon with cruise control or my '87 wagon that originally came with cruise control.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 91waggin View PostLater being what? I'm pretty damn sure my 91 has the vacuum dump on the pedal, because I've been under there several times when I had to replace the brake light switch.
I think he meant aero, mine doesn't have the vac half-moon thingsigpic
its not the half moon thing. thats for something else.
90s Towncars don't have it at least. I think the aero Vic and GMQ also do not have it, at least by 95 or so. Its whenever they added that extra switch to the master cylinder that was the subject of a recall about a year ago. ots of mid-late 90s cars were affected.86 Lincoln Town Car (Galactica).
